Sorry fot this newbie question, but how can I measure a Speaker impedance in ohms? It must be 4 or 8 Ohms. I've got a polimeter, but it tells on every speaker I measure that has got a 0 Ohm impedance, so it doesn't work, is this a normal situation, can I do this with the polimeter or do I need something more?
Any suggestion? sorry for the newbie question, is there any post to help begginers in questions like this? Thanks |
#2 |
An ordinary multimeter with a low ohms resistance range (usually x1 on an analogue meter) can be used - a 4ohm speaker will usually measure around 2.5 to 3.5 ohms DC, while 8ohm speaker can be 5.5 to 7 ohms or so.
Cheers |
| [Newbie] PA speaker impedance problems | chaos.squirrel | PA Systems | 6 | 22nd December 2006 07:55 AM |
| Speaker Workshop - using "Measure -> Passive Components" to measure ESR ? | percy | Multi-Way | 0 | 12th March 2006 09:18 PM |
| How to measure the output impedance of the DAC chip | ergo | Solid State | 2 | 9th June 2004 07:07 AM |
| How do I measure OPT impedance? | roundel325 | Tubes / Valves | 1 | 30th April 2004 07:28 PM |
| How do I calculate (or measure) my amp's output impedance? | Saurav | Tubes / Valves | 22 | 27th September 2003 03:55 AM |
| Page generated in 0.06233 seconds (67.70% PHP - 32.30% MySQL) with 10 queries |
