Old 7th July 2012, 08:14 AM   #1
Default Crossover for BMS 4590 driver
Does anyone have any schematics for any proven "custom" crossovers for the BMS4590 ( 8 ohm ones) I have been unsucessfully attempting the flatten the response of these drivers by adding notch filters etc. ( running in a 200hz Le Cleach horn crossed actively @ 350hz)
I have looked on the web and have seen ones on german pages for eckhorns etc, and but i don't understand from my simple calcs what they are doing as the notch filters seem to be in places in the freq range where i don't think i need them.
Old 7th July 2012, 09:30 AM   #2
Brett's Avatar
Go active. I had a decent response dialled in in minutes with mine.
Old 8th July 2012, 09:26 AM   #3
thanks for that advise, however i don't really want to go active with the MF to HF crossover as i haven't the room for another set of monoblocks!!
Old 8th July 2012, 09:45 AM   #4
Brett's Avatar
Have fun then. They have a mongrel of a Z curve from memory (I haven't used mine in years). Best bet is to measure them and sim an xover out with Passive Crossover Designer.
Old 8th July 2012, 10:10 AM   #5
Banned
I know Alk Universal networks which are specially designed to use in Klipsch heritage horn speakers work great with BMS CDs. take a look may give you a clue:
Old 8th July 2012, 10:25 AM   #6
Brett's Avatar
^^ It would get you functional, ie make sound, but it's hardly a good combination. I had Khorns with ALKs when I first got them.
Old 8th July 2012, 08:03 PM   #7
i had seen this and i throught it would be a starting point... KS-1804
Old 9th July 2012, 10:12 AM   #8
First X/O version of KS-1804 also included passive high-pass (C1011) for 4590/M. -6dB frequency was close to 410 Hz with SL250-2 horn:
This could be one starting point but requires tuning for selected horn. I have also additional active filtering for resonance @ 3 kHz and peaks @ 7 kHz and 10 kHz.
Br,
KS
Old 9th July 2012, 11:44 AM   #9
I have all the bits for this x-over, will build it and see how it compares to the std BMS x-over i already have. From my measurements todate there is a peak at 3kHz which is the most noticeable.
Will report back once i have the x-over up and running and measured.
Old 9th July 2012, 12:39 PM   #10
mdocod is offline mdocod  United States
Send a message via AIM to mdocod
If you can take your measurements, and get them into simulation, you will be able to knock down response peaks in a matter of a few hours work in simulation.
For Sale: BMS Coax Compression Driver 4590 NYCOne Swap Meet 1 16th October 2011 03:36 AM
Looking for BMS 4590 crossover schematics jaskierster Multi-Way 3 17th September 2010 05:36 PM
new BMS triaxial driver angeloitacare Multi-Way 2 26th June 2008 03:23 AM
BMS 4538 Driver vs Celestion CDX1-1745 gkoutz Multi-Way 0 1st August 2007 02:54 PM
BMS H4591 midrange driver slowmotion Multi-Way 0 10th February 2004 11:45 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
