Tools needed and help with nailing.
Old 3rd July 2012, 09:46 PM   #1
Elias318 is offline Elias318
Default Tools needed and help with nailing.
Hello i am about build my first speaker setup, Curts stentorians. the only problem is i dont have a nailgun or the money for one. So i was wandering if i should I use a hammer and a nail or drill some pilot holes. I am using 3/4 MDF. Also should i use wood glue at all? Right now all i have is a 18v drill and 6' and 1' hole cutter, and also a jigsaw for the braces. Also what size nails should i use and what size drillbits. Thanks!
Old 3rd July 2012, 10:40 PM   #2
tvrgeek is offline tvrgeek  United States
Glue only. Plain old yellow glue. No need for any nails. A bit of rope, masking tape, or real clamps if you have them. If you insist on help keeping things aligned, then sure, drill some thin nail holes while you are doing dry fit, tap the nails in lightly so you can pull them out after the glue is dry. Drill size? TEST of course! MDF will split with a nail too tight. That is why we don't screw MDF either.
Old 3rd July 2012, 11:16 PM   #3
Okay just to be clear, your saying glue the pieces together than after it drys, hammer some nails in lightly?
Old 4th July 2012, 12:06 AM   #4
maxro is offline maxro  Canada
maxro's Avatar
No, that's the exact opposite of what tvrgeek is saying. Best just to forget the nails.
Also note that a 6" hole saw (let alone a 6' one) will rip your wrist off if you use it with a hand drill. You will need a drill press, or better yet, a router with a circle guide.
"No one likes jazz that much; even the guy playing it had to take drugs." -Bart Simpson
Old 4th July 2012, 12:20 AM   #5
So your saying i should just glue it together and use some clamps? is that enough? Will the enclosure be reliable?
Old 4th July 2012, 12:28 AM   #6
puppet is offline puppet  United States
A little trick for finding the right hole size for your nail ... cut the head off a nail and put the shaft end in the drill chuck. Drill with the nail ... can't miss.
Old 4th July 2012, 12:28 AM   #7
maxro's Avatar
Yes, yes and yes. (to post #5)
Old 4th July 2012, 12:31 AM   #8
I'd provide some interior corner bracing myself. Mitered glue block, square cut blocks ... something to increase the surface area of the joint. These can be applied after the joint is glued and set.
Old 4th July 2012, 12:33 AM   #9
ChicagoJTW is offline ChicagoJTW
A jig saw with a fine-tooth blade will cut a 6-inch hole just fine. MDF does not require nails, but the most important thing when glueing is clamps. More clamps are better than fewer. You can use cauls to spread the pressure if necessary.
Old 4th July 2012, 02:52 AM   #10
Michael Chua is offline Michael Chua  United States
Michael Chua's Avatar
Basically, that's about it. Glue and clamp.
Click here for an example of how to build a speaker.
ampslab
Tools needed and help with nailing.Hide this!Advertise here!
tools timwebb Car Audio 0 9th December 2011 04:09 AM
Magellan GPS PC tools needed Wavebourn Everything Else 0 3rd April 2007 08:56 PM
Design tools needed augerpro Multi-Way 8 16th September 2006 12:48 AM
New tools edjosh23 Everything Else 25 21st July 2006 08:20 AM
Copyright ©1999-2017 diyAudio
