Dipole idea: mount midrange drivers back to back without baffle - Page 5 - diyAudio
Old 23rd October 2012, 12:46 PM   #41
Originally Posted by OllBoll View Post
Here is a test baffle with a placeholder plate for the midrange, in the weekend I will try to do some polar responses and see if it measures as nice as I predict it will =)
If it's as my prediction it will be close enough to -6 db @ 60 degrees all the way up to 15 khz in all directions.
Your tweeter arrangement reminds of the original Bose 601 of the 70s...I guess in that case the 601 too would qualify as omnidirectional.
Are you planning to wire all the tweeters in the same phase ? SL found better results with the Orion rear tweeter wired out of phase FYI...cant explain why !
The differing subjective perceptions of 2 back to back enclosure mounted drivers, wired in bipole vs dipole phase , even when used for the mid to high spectrum is very interesting...have not seen a good explanation though ??!!
Old 23rd October 2012, 03:48 PM   #42
badman is offline badman  United States
Custom Title
badman's Avatar
Probably has to do with needing to be out of phase to sum correctly in the rear lobe, otherwise you'll have a cancellation notch in the rear lobe.
"The dawn of Bose created the "Man Cave" and reduced testoterone levels worldwide by 18.5 per cent" Peteleoni
Old 24th October 2012, 12:24 AM   #43
OllBoll is offline OllBoll  Sweden
In the test the rear ring was out of phase. My new omnis will be monopoles so they will only have a single ring of four on each speaker and all of them will be in phase yes.
And what it resembles the most is the pop box =)
Old 24th October 2012, 05:50 AM   #44
CLS is offline CLS  Taiwan
Have you seen this?
http://www.diyaudio.com/forums/multi...ml#post2853704
Old 24th October 2012, 11:31 PM   #45
Originally Posted by CLS View Post
I saw it a long time ago but then forgot about it =)
It's an interesting concept, would be very interesting to hear impressions of that speaker type compared to normal omnis or dipoles like say the Orion.
Closed back midrange drivers - problems? River757 Multi-Way 6 17th January 2012 02:46 AM
CHR-70 back mount Kjeldsen Full Range 23 29th October 2011 07:31 AM
Driver mount back pressure silverhairbp Full Range 22 26th August 2011 03:47 AM
How to get TSP for two drivers back to back in anti-phase (dipol)? schro20 Full Range 1 6th January 2010 09:58 AM
Closed back midrange drivers 4" maybe 3" - recommendations please RobWells Multi-Way 2 22nd February 2007 04:59 PM
Copyright 1999-2017 diyAudio
