Old 28th June 2012, 03:37 PM   #1
Default Driver selection advice
I am looking to build a 2.1 set of active monitors and an active sub, with an Apple Airplay device as a source.
I listen to compressed, over eq'ed and over produced popular music, 80's stadium rock - journey etc and the odd bit of Einaudi. Don't hate me.
I'm looking to use the Hypex AS2.100 plate amps.
I need help on driver choice, I'm thinking treble, 5" mid/bass and then a sub - which I have no idea about.
I'm only an enthusiastic amateur, so happy to be told the whole idea is wrong / there is a better answer.
I'm not overly fussed on budget, I'm comfortable with say £500-750 on drivers. But if there as twice as good for £100 more, I'd pay it.
Thanks in advance!
Ben
Old 28th June 2012, 04:07 PM   #2
Taco is offline Taco  Netherlands
There are lots of possibilities with that budget. You cannot go wrong with:
- Seas Prestige
- SB Acoustics
Both brands are easy to find online (e.g. Europe Audio).
I would suggest the following:
Seas
- 5" Mid H1488-08 L16RNX
- Tweeter H1499-06 27TBCD/GB-DXT
SB Acoustics
- 5" Mid: SB15NRXC30-8
- Tweeter: SB29RDNC-C000-4
There are many more combinations, using the plate amps should result in a nice compact setup.
Old 28th June 2012, 10:56 PM   #3
What is you listening situation/ room? I'd only go for a 2.1 system if you're at a computer desk or space is severely limited. A pair of good 3 ways with decent woofers would suit the music you like much better, and there are plenty of designs out there you can copy - check out Troels' site DIY Loudspeaker Projects Troels Gravesen
(& you can still bi-amp for excellent results)
Impedance varies with frequency, use impedance plots of your drivers and make crossover calculations using the actual impedance of the driver at the crossover frequency
Old 1st July 2012, 11:22 AM   #4
I'm really looking for something quite compact... as it the way these days.
Old 1st July 2012, 11:23 AM   #5
- Seas Prestige
- SB Acoustics
Seas
SB Acoustics
Thank you for your advice.
What are Morel like? Specifically EW428 and ET 448?
Also Scan-speak seem high end (read:expensive), does this mean they are fantastic?
Thanks, Ben
Old 2nd July 2012, 02:59 AM   #6
the 5 inch scan-speak relevator drivers are very very good.
try this
W1501/
noob
Old 2nd July 2012, 09:34 AM   #7
try this
W1501/
Thanks, does anyone have an opinion on Scan-speak...
Illuminator vs. Revelator?
Thanks, Ben
Old 2nd July 2012, 10:15 AM   #8
mondogenerator's Avatar
the scans look good. Ive never used them though. The high price and low Qts puts me off them. Plenty have used them and sing their praises.
It still amazes me every time I get something right
Old 2nd July 2012, 10:38 AM   #9
This Zaph|Audio - ZD5 - Scan Speak 15W8530K00 and Vifa XT25
is probably the best 5" 2 way design out there and its not cheap. If your
not a volume freak the floorstander basically doesn't need a subwoofer.
In the UK, with drivers from Europe Audio - Home page
probably best bang for buck design you could build is :
https://sites.google.com/site/undefinition/diy/amiga
Again a sub is not really needed.
For a sub take a look at :
https://sites.google.com/site/undefinition/speedster
http://www.humblehomemadehifi.com/do...Mk-II_copy.pdf
http://www.humblehomemadehifi.com/do...0HATT_copy.pdf
http://www.humblehomemadehifi.com/do...III-C_copy.pdf
rgds, sreten.
There is nothing so practical as a really good theory - Ludwig Boltzmann
When your only tool is a hammer, every problem looks like a nail - Abraham Maslow
Old 2nd July 2012, 11:22 AM   #10
Looking at your amplifier choice its £400 for 2 channels.
Go that way if you want to.
I'd go for something like this and passive x/o speakers :
http://www.richersounds.com/product/...ara-pm5004-blk
PM5003 <I>vs</I> PM5004 | Stereophile.com
Marantz PM5003 integrated amplifier | Stereophile.com
You really can't go wrong for £150.
rgds, sreten.
looking for advice on driver selection... armstrom Full Range 18 28th January 2011 01:41 AM
Advice for transformer selection. beppe61 Power Supplies 20 2nd August 2007 11:37 AM
Driver selection advice Kittle Subwoofers 5 18th June 2004 05:52 PM
low on cash, need advice on driver selection etc. please. Kram Multi-Way 89 14th November 2002 07:51 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
