tweeter choice: dome or ribbon? - Page 7 - diyAudio
Old 3rd July 2012, 10:33 AM   #61
Once upon a time I thought I had a few 'bad recordings' but as my speakers got better over time the number of 'bad recordings' in my possession decreased.
However since then the Loudness Wars kicked in and to my ears grossly over-compressed stuff does sound less nauseating through crappy speakers than good ones.
Or may it is just that when I play non-compressed material through good and bad speakers I hear a vast difference while the over-compressed stuff sounds pretty much the same through either speakers.
A kind of inverted expectation bias.
Old 3rd July 2012, 12:30 PM   #62
StigErik's Avatar
Yeah, that badly compressed stuff they put out nowadays sounds like **** no matter where or on what you play it....... too bad. And record companies wonder why their records dont sell...????
dipoles dipoles dipoles dipoles dipoles dipoles dipoles dipoles and dipoles
Old 3rd July 2012, 02:00 PM   #63
puppet is offline puppet  United States
There is about a 3dB difference in "modern" recordings as opposed to stuff produced in the 70's and 80's. I've noticed this and adjust at the input stage ... and it's a PITA. Analog processing might be fine with the increased input level variance ... digital, not so much.
Old 3rd July 2012, 02:06 PM   #64
Originally Posted by StigErik View Post
+1
Blaming "bad" recordings is a lousy excuse for not looking into the real problem --- the speakers, the room and how they interact to create the sound that you are really listening to. And in most cases, the result is exceptionally bad.
I guess you don't listen to much American pop?
Old 3rd July 2012, 02:30 PM   #65
mondogenerator's Avatar
haha i agree. De-essers just seem badly used, coupled to a cd 0dB master makes for that sound imo. Id agree, without knowing exactly, that master levels even im the 90s were maybe 3dB lower. When i mix, i always master at -3dB. It just works better for me.
Back OT, in a way, i will post my circuit for RAART, as he expressed an interest in seeing it.
I may have posted in another thread already...memory like a seive.
In fact its probably in my signature thread, i should check
Balancing the things I must do, with the things I'd like to do...This is a skill (or a luxury) amongst many that I do not possess.
Old 3rd July 2012, 02:38 PM   #66
DrDyna is offline DrDyna  United States
DrDyna's Avatar
It's probably because hardly anything is mixed or engineered with high end systems in mind anymore, they're all focused on what's going to sound good played on someone's wal mart car stereo or plastic rack system, lots of "thunder and lightning" EQ and they all use Yamaha NS10Ms to do it.
Old 3rd July 2012, 02:46 PM   #67
@ RAART:here is the circuit for 4th order HP @ 3.5kHz, the 52 ohm lpad resistor can be removed, as it does very little.
http://static.diyaudio.com/forums/ga...Neo3CD3_5H.jpg
As you may be able to see from the frequency plot below, its just about -40dB at the 1.5k resonance. The elliptic filter is much sharper but attenuates this even further.
I hope this is of some use, even for just a starting point for the filter for your jordans
Old 3rd July 2012, 03:23 PM   #68
StigErik's Avatar
It's more like 10 dB louder today than in the "good old days"....
Old 3rd July 2012, 03:24 PM   #69
StigErik's Avatar
I prefer music.
Old 3rd July 2012, 03:30 PM   #70
I've got a fair few cds from the '80s and '90s and their rms level is around
-12dBFS. They sound good.
Some stuff I got after '05 or so has an rms level of -6dBFS or even less. They sound shite.
I will never ever buy a cd that features the name Lord-Alge in the credits as that is a clear indicator for grotesque over-compression. The really sad thing is that I read an article about one of them (they are two brothers) in SoundOnSound and practically all the compression they apply is done with rather tasty vintage compressors which of course are analogue.
It doesn't really matter if the over-compression is applied analogue or digitally, it's all rubbish if overdone.
swap dome tweeter for ribbon? lupin..the..3rd Parts 2 23rd July 2011 02:16 AM
Fountek ribbon tweeter 3cm2 ribbon black square alumunum faceplate lduarte1973 Multi-Way 3 16th June 2009 08:50 AM
ATC mid dome and ribbon tweeter Vil Multi-Way 69 16th September 2005 09:08 AM
Tweeter Box Crossover with Ribbon and Bullet Dome Tweeters doccbst Planars & Exotics 2 5th August 2005 04:54 PM
ribbon vs dome tweeters MyNameIsJake Multi-Way 15 21st April 2005 09:17 AM
Copyright 1999-2017 diyAudio
