#11 | |
My Heil is crossed at 2K (18dB) to my Audax HM130C0. Wonderful combination.
AmpsLab.com |
#12 |
thanks Simon, the reasons you mention are the reasoning behind me taking a listening break until i have a flat crossover.
The domes sound ok really, but it sounds more of a case of what the ribbons lack in their reproduction, rather than the reverse. Its this that makes me look at the domes colouration, rather than the THD of the ribbon. I have seen waterfalls and THD measures posted on techtalk i think, below about 2.5k the THD rises, but above 3k its below -40dB, the waterfall shows a spike in the same region, so i plan to cross higher than this.
It still amazes me every time I get something right |
#13 |
Thanks Michael, those do look nice. Similar box size to my AP130ZO, although I dont think there is much special in the AP range motor, no shorting ring, although that doesnt make them awful. The HM range are likely a lot better.
#15 |
#16 |
The Heil isn't really a ribbon though, is it? I was always under the impression that ribbons moved in-out, the Heil kinda does a "squeeze to center".
#17 |
In some circles, these are considered worlds best. I only used them once in a box in the back of a Chevy Blazer, they did sound great.
Never understand why they stop making great speakers! |
#18 | |
Wiki has some information on Heil AMT
AmpsLab.com |
#19 | |
One of these days I'll try to cook something up myself. |
#20 |
yeah a heil is a motion transformer, which i THINK is like a magnetostat, except pleated, and attraction is between folds, rather than a pseudo ribbon magnetostat. All of these appeal to me, budget was important, so i chose the neoCD3.5H, versus the Mivoc and visaton magneto. A raal or heil would be good, i challenge you to find an example for £40 each, and ill buy. The pinching motion is another 'lever' of mechanical advantage, like the horn is to the 3.5h
| swap dome tweeter for ribbon? | lupin..the..3rd | Parts | 2 | 23rd July 2011 02:16 AM |
| Fountek ribbon tweeter 3cm2 ribbon black square alumunum faceplate | lduarte1973 | Multi-Way | 3 | 16th June 2009 08:50 AM |
| ATC mid dome and ribbon tweeter | Vil | Multi-Way | 69 | 16th September 2005 09:08 AM |
| Tweeter Box Crossover with Ribbon and Bullet Dome Tweeters | doccbst | Planars & Exotics | 2 | 5th August 2005 04:54 PM |
| ribbon vs dome tweeters | MyNameIsJake | Multi-Way | 15 | 21st April 2005 09:17 AM |
