Changing speakers on digital piano
Old 24th June 2012, 05:29 PM   #1
timtex is offline timtex
Default Changing speakers on digital piano
Hello, I need some help with an Acorn DCP-310 digital console piano. I just bought it, and I'm not pleased at all with the sound. It has two woofers mounted on the underside of the cabinet, which are pointed at the floor, and also tweeters on either end of the keyboard. I've attempted to make adjustments to the sound using the controls, but it still sounds muffled and boxed in. I plugged Numark monitors into it using the RCA jacks on the front, and that sounds pretty good. The problem is, the piano circuitry has panning which makes the lower notes louder from the left speaker, and higher notes from the right. When you plug in external speakers, there's no panning. My question is, can I disconnect the built-in speakers, and connect those wires to passive 20 watt external speakers? I took the lid off, and the speakers are connected with 20 AWG wire and quick disconnects. But the way they're wired is not something I'm at all familiar with.
Old 24th June 2012, 06:01 PM   #2
Pano is online now Pano  United States
Pano's Avatar
Welcome to the forum!
Usually yes, you can disconnect the internal speakers and connect external speakers of equal or higher impedance. Are the internal speakers 8 ohm? Can you tell?
Old 24th June 2012, 06:48 PM   #3
Thanks for your response. I took the lid off again, and I cannot see any markings on the woofers. The specs listed in the manual are no help either. However I looked at the tweeters too, and they are marked 4 ohm 10 watts. This piano is sold with different brand names, and another brand's website says the speakers are 20 watts. Anyway, the woofers are about 4.5" across. Two wires go from the circuit board to the woofers, one white and one blue or brown depending on right or left. The wires are "pigtailed" where the quick disconnects clip onto the speaker and then go on to the tweeters where they clip on there. If I disconnected the wires, can I use more quick disconnects to make them longer? I'm starting to wonder if this is worth it, and I'm thinking about just getting a keyboard amp so that the stereo aspect isn't a consideration.
Old 24th June 2012, 06:51 PM   #4
Pano's Avatar
The keyboard amp is certainly the quick and easy route! You might be happier with it, too.
But you can try connecting to external 8 ohm speakers if you want. Just keep the volume low at first until you're sure it's working. Should not be a problem at all.
Take the Speaker Voltage Test!
Old 24th June 2012, 08:41 PM   #5
Okay, but I'm only familiar with the most basic speaker connections. If I disconnect the wires on each speaker, I'm left with two wires that have quick disconnects on them. Assuming I buy some passive speakers with standard red and black wire connections, how do you connect them to the speaker? And how do you know which wire goes where? I'm kind of worried about cutting the wires, but I guess I could always replace the quick disconnects. Also, the wire they used looks more like electrical wire, which is kind of scary to me!
Old 24th June 2012, 09:15 PM   #6
tsiros is offline tsiros  Greece
tsiros's Avatar
Send a message via MSN to tsiros Changing speakers on digital piano
whoa whoa whoa
that thing has midi out
step 1: connect it to your computer's soundcard or a midi-in
step 2: use super high quality software synth on the computer
step 3: use your hifi as output
step 4: ???
step 5: awesome sound
Old 24th June 2012, 11:38 PM   #7
Thanks, yes, it does have midi. But I would have to move my PC into the living room, and that's a little more involved than what I want to do. I'm thinking now that if I could find up-firing speakers it might solve the problem.
Old 25th June 2012, 03:27 AM   #8
Pano's Avatar
If the built in speakers have just two wires going to each, it's simple. Just connect those same wire to your new speakers. It doesn't matter much which wire goes to which terminal. If there is a color code or stripe on the wires, just connect the same way to your new speakers. If not, well... no worries!
Speaker wire is much like lamp cord. No problem tho, it's low voltage.
Old 25th June 2012, 08:22 PM   #9
Okay, that makes sense. I'm thinking about getting a terminal plate and putting it on the back of the piano to keep the lamp cord inside the cabinet, and make things more user friendly too. I appreciate your help, and maybe someone else will also benefit from the information.
Old 25th June 2012, 09:24 PM   #10
Pano's Avatar
You're welcome!
Terminal plate is a good idea. I was thinking about a 1/4 jack that has the switch in it. When you plug in the external speaker, it cuts off the internal. Like a headphone jack.
Maybe more trouble than it's worth.
Changing speakers on digital pianoHide this!Advertise here!
DIY digital piano speakers 454Casull Multi-Way 13 14th May 2011 04:54 AM
need driver for specialized digital piano loudspeaker ChrisA Multi-Way 5 22nd December 2009 04:21 PM
Samick digital piano schematic wanted Dev Instruments and Amps 1 22nd July 2009 03:23 AM
