Attenuator for tweets or mids - diyAudio
Old 24th June 2012, 02:18 PM   #1
Banned
Default Attenuator for tweets or mids
this thread is the result of a silly question someone asked me
can we use resistors in signal path to attenuate a speaker? for example to attenuate a tweeter which has a higher db than other drivers... or to attenuated mid-range?
if I got a "Yes"here, what Ohm should we use? can a variable pot (like ALPS) be used to do so? we should put it on a small PCB with a jumper, while the jumper is locked all the signal passes through, unlock the bridge and here we adjust the pot!
Alkeng.com have some nice attenuators: link
Old 24th June 2012, 02:26 PM   #2
wintermute's Avatar
Yes you can. do a search on Lpad. You can buy variable ones but they don't work like normal potentiometers.
Tony.
Any intelligence I may appear to have is purely artificial!
Some of my photos
Old 24th June 2012, 02:50 PM   #3
Banned
Tony.
I far as I know potentiometers are either liner or logarithmic... both will do the -db function but I think liner one is better and easier to adjust... I got some high quality Alps 100KAX6 (logarithmic) and 100KBX2 (liner) pots... can I use them?
Old 24th June 2012, 03:23 PM   #4
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
well, I think resistors with 5watt is minimum power rating
using too big fixed pad resistors, it might be interesting to place a variable resistor in paralel with each
Old 24th June 2012, 04:36 PM   #5
Banned
I learned from Klipsch crossovers to use autotransformer to attenuate and do -db function... will using resistors result in destroying some of sound or increasing sound distortion?
Old 24th June 2012, 04:44 PM   #6
these days I use only series resistors
destroys the signal ?
well, isnt that the purpose
joke aside
it all affects the signal
just make sure it helps more than it hurts, and you have gained more than lost
Old 24th June 2012, 04:44 PM   #7
picowallspeaker's Avatar
Transformers are useful to match impedances , but can eat most of the budget when making an Xover . You can read the part regarding the L-pad adjustments in the sticky thread made by Allen B ; they can become part of the X-over itself , like determining
shape , steepness depending on the position .
Old 24th June 2012, 11:19 PM   #8
L pad calculator - attenuation dB damping impedance decibel loudspeaker speaker voltage divider - sengpielaudio Sengpiel Berlin
Impedance varies with frequency, use impedance plots of your drivers and make crossover calculations using the actual impedance of the driver at the crossover frequency
WTB: Zaph ZA14 Mids & SB29RDC Tweets ernperkins Swap Meet 0 8th April 2012 10:27 PM
Woofs, mids, tweets, fullranges, coaxes (Seas, Tang Band, Fostex, Morel) audiokinesis Swap Meet 26 24th July 2011 08:34 PM
F/S: Morel Supreme tweets, MDM-55 mids audiokinesis Swap Meet 2 23rd July 2011 05:40 AM
which chip/design for mids/tweets amp? madisonears Chip Amps 10 18th January 2008 03:40 AM
Wanted- reasonably cheap 5 1/4"mids and tweets Puggie Swap Meet 0 22nd October 2004 09:37 PM
Copyright 1999-2017 diyAudio
