#51 |
Great Dunlavy interview..Loudspeaker designer John Dunlavy: By the Numbers... | Stereophile.com
Dunlavy SC-1 measurements.. Dunlavy Audio Labs SC-I loudspeaker Measurements | Stereophile.com Notice the inexpensive vifa tweeter's response at 1.2 khz. Ouch! I owned these, and both tweeters blew..
It's not what you don't know that causes trouble. It's what you do know that just ain't so..Mark Twain Last edited by Remlab; 29th September 2012 at 09:31 AM. |
#52 | |
1) I'd leave all coil "as it is", but maybe leave the place on new board if you decide in future to use foil coils. 2) L2 and L5 coils are used in networks for correction of freq.response, so their exact values is important (both - inductance and resistance) 3) C15 and C3 exact value is required as in (2) - but both of them making 1.504uF, so you can replace it with one 1.5uF capacitor 4) C7 and C10 also makes 1.504uF, so you can replace it with one 1.5uF capacitor 5) C6, C8, C9: replace them to 8.2+6.8+1uF 6) C4: 50uF - this should be exact value as stated in (2). For example 47+1.5+1.5 7) C1,C13,C14: 24.5uF -> 22+22+0.47 (or 20+20+2.2+2.2) 8) C2, C11, C12: I'd leave it as it is 20+10+10 9) C5, C16, C17, C18: 70uF -> 33+27+10 10) all resistors -> MOX 10W What kind of parts to use: If price no object, I'd use best possible caps for (5), (6) and (7) - I suggest you to try there Auricap XO. for C3, C4, C15 quality is not so important, you can use something like Mundorf MCap250. For (4): you can use Auricap XO, or also try inexpensive Electrolytics like Mundorf BG ("plain" - new name ECAP70)- you need to listen what is better. Not always expensive cap is better. For Bass section I suggest MCap400, but MCap250 also will be fine and You can try here also Electrolytics - as what I've noticed that in some constructions replasing electrolytics to plypropilene in bass can make it more exact, but a bit "dry". Here you need to try and listen.
Auricap XO, Mundorf capacitors, coils, MSolder, terminals, DH-Labs interconnect & speaker cables, internal wiring for DIY & upgrades are here: www.audiohobby.eu |
#53 |
Audio Junkie
well things are on hold. I have all new inductors and MOX resistors and got hung up on capacitors.
I was extended and offer from someone in the high end cap industry for some special caps and thats what started this whole project in motion and well you know...sometimes people say things just to make themselves look better and when you call them up to collect...they turn around and say "oh, i guess you were serious about that??" and the deal vaporizes! So things are on hold until I can get an alternate affordable solution worked out... In the meantime. the refoamed woofers work great. and I have been enjoying them as is with various amps, my Zen Lights mainly, various soundcraftsmens, my Atma Prototype, Audio Research VS60, my old HK 330C, even a little Dayton sonic t-amp!
It's not about what you can BUY...It's about what you can BUILD! |
#54 | |
#55 | |
It's not what you don't know that causes trouble. It's what you do know that just ain't so..Mark Twain Last edited by Remlab; 30th September 2012 at 12:11 AM. |
#56 | |||
I read the reviews of both the SC-1 and SC-IV. Neither review or its accompany measurements points to any distortion or compression from these drivers at their operating frequencies. As a matter of fact, at least on the SC-IV, its huge dynamics were mentioned in the review. Just an excerpt from the SC-IVA review: The SC-IV/A hasn't completely avoided sounding like a speaker, but, compared to the SC-IV—itself already low in speaker colorations—it sounds more like musical instruments and voices and less like an electromechanical contrivance. The SC-IV/A's sound had tremendous coherence: despite being a complex multiple-driver system, it speaks with one voice. There is exceptional top-to-bottom integration, with no audible cues as to where in the range the different drivers take over. One visiting audiophile friend who was unfamiliar with the speakers said that if I hadn't taken off the grille to show him the drivers, he would have thought he was listening to a speaker with a single driver. If there was any distortion like you mentioned, this would not be possible. |
#57 |
I stand corrected. The v's are very different from the rest of the lineup.
I loved what my Dunlavy's did below 93db, but the tweeters did eventually give out. What tweeters did he update to?
It's not what you don't know that causes trouble. It's what you do know that just ain't so..Mark Twain |
#58 | |
#59 | |
One thing I love about John(and probably one of his biggest weaknesses as a businessman) was his almost compulsive nature at small detail in engineering, and in voicing his speakers. When he found an improvement to something, he would always come back to my studio and install and tweak it. As I said earlier, he came back to my studio four times before walking away from my SC-V - and then eventually getting too sick to return for good. When he told be that each SC-V spent 30hrs in the anechoic chamber, and being listened to and tweak, I was blow away. Makes it worth my investment to know this. |
#60 | |
Audio Junkie
Dave
| John Krutke Designs adaptable for Home Theatre? | dcourtney | Multi-Way | 15 | 2nd January 2005 11:51 PM |
