Inductors, Trivial Or Major Improvment??
Old 24th June 2012, 12:28 AM   #11
Zero Cool is offline Zero Cool  United States
Zero Cool's Avatar
with as many parts and resistors on these boards. I highly doubt they would try and save the cost of another resistor LOL! but I get your point. I am replacing the inductors only because I am keeping the stock crossover boards intact and building new boards to replace the stock boards with. same circuit. same values. just new board, new parts.
The caps have a plastic core with a hex hole in the middle for winding. each end is exposed and you can see the layers wound up with solder sputtered on each end and then the wire with the loop soldered on. a thin wrap over the winding. im sure this is pretty normal inside of some caps. but these are just caps i have never seen before. not sure of the brand??
The stock PCB is double sided and very thick. the top side is a large ground plane. the bottom has very crude etched traces.
It's not about what you can BUY...It's about what you can BUILD!
Old 24th June 2012, 12:35 AM   #12
Pano is offline Pano  United States
Pano's Avatar
I dig those crazy cap leads! May have to try that one myself.
Inductors, Trivial Or Major Improvment??Hide this!Advertise here!
HELP: Trivial Balance Control for Balanced B1 rgheck Pass Labs 1 9th July 2010 06:20 PM
Major Newb Question Nexter Digital Source 0 1st April 2008 05:16 PM
Just a trivial question about capacitors. beppe61 Parts 21 4th September 2006 09:26 PM
Major Vibration Phrozen06 Car Audio 4 18th August 2005 02:36 AM
