Crossover frequency/order question - Page 2 - diyAudio
Old 23rd June 2012, 11:58 AM   #11
Default mixed order crossovers
Eric, when you say mixed order crossovers I assume you mean that for different xo points not at the same xo point. correct? I wouldn't have a HP 2nd order at 350hz and a 1st order LP at 350hz?
Old 23rd June 2012, 02:13 PM   #12
jerome69's Avatar
Originally Posted by jimbones View Post
I think I will start with only one mid. thanks.
I never designed a notch filter though. link?
CalcTool: RLC or LC circuit calculator
RLC series.
L = 0.22 mH
C = 3.3 uF
R = 0
F =6kHz.
Old 23rd June 2012, 02:23 PM   #13
diyAudio Member RIP
I have or can get most of this info. However Dayton
doesn't publish frequency response curves .
Hi, They do. http://www.parts-express.com/pdf/295-368s.pdf rgds, sreten.
Old 23rd June 2012, 05:35 PM   #14
Default Breaking up is hard to do!
Whoa!!!
Had i seen that strange behavior past 1khz I may not have purchased this woofer!! looking at that spec makes my mids look pretty good!!
Ok so it looks like I definitely need a 2nd order (or more?) filter. the other alternative is Jerome posted a notch filter for me. So i could go first order with a notch. Trial the 6 1/2 mid on its own baffle and if it doesn't work get another driver.
Old 23rd June 2012, 09:11 PM   #15
mdocod is offline mdocod  United States
Send a message via AIM to mdocod
Mixed order means that you may very well have a high pass and low pass targeting the same "x-over frequency" that are different order slopes electrically, in order to produce symmetrical slopes, in phase, acoustically.
Eric
Old 23rd June 2012, 10:28 PM   #16
Default Old Dog learning old tricks
Eric
Great. When designing I sometimes needed to do that but for some reason I thought it was taboo. OK so put a steep slope on the Rs270 and a shallow one on the Dynaudios. Sent you PM
Old 23rd June 2012, 10:34 PM   #17
mondogenerator's Avatar
if you pick a big enough '1st order' coil to roll off the response slightly, around youre 6dB rate, you can always add a notch filter higher up, or maybe just a capacitor?
You should be able to get a drooping curve, with a breakpoint, after which it rolls off at a faster rate.
There are free crossover simulators, and other things around the internet. Others here far more than I about them, so perhaps someone can recommend?
Balancing the things I must do, with the things I'd like to do...This is a skill (or a luxury) amongst many that I do not possess.
Old 23rd June 2012, 10:38 PM   #18
Also checkout
Why 2nd Order Is best or not
Gentle Cue
Old 23rd June 2012, 10:45 PM   #19
Default series-parallel?
RLC series.
L = 0.22 mH
C = 3.3 uF
R = 0
F =6kHz.
Is that series or parallel. So this is centered around 6khz.
Old 23rd June 2012, 11:16 PM   #20
DBMandrake's Avatar
It's not only not taboo, it's extremely common, and pretty much necessary if you don't have driver acoustic centres aligned and expect any sort of decent phase tracking through the overlap region...
- Simon
Question about tweeter polarity 2nd order crossover reveonss Multi-Way 17 6th April 2014 11:12 PM
Frequency range/ crossover question Fred75 Multi-Way 15 2nd February 2008 07:04 PM
first order crossover question MisterTwister Multi-Way 3 9th June 2007 11:03 AM
Crossover Frequency Question Decado Multi-Way 5 28th July 2005 04:13 AM
Crossover order and phase question Westrock2000 Multi-Way 36 31st March 2003 07:00 PM
Copyright 1999-2017 diyAudio
