What is most important when choosing driver?
Old 22nd June 2012, 10:27 PM   #21
ScottG is offline ScottG  United States
Originally Posted by Starre View Post
And for tweeter: Seas 27TFF
For a "2-way" I'd use the Scan Speak Discovery 10F/4424G00 (or its 8 ohm version) for a "tweeter"..
http://www.zaphaudio.com/temp/Scan-S...4424G00-FR.gif
http://www.zaphaudio.com/temp/Scan-S...5-30-45-60.gif
http://www.zaphaudio.com/temp/Scan-S...424G00-CSD.gif
http://www.zaphaudio.com/temp/Scan-S...4424G00-HD.gif
..and then design around that.
perspective is everything
Old 22nd June 2012, 10:45 PM   #22
Starre is offline Starre  Sweden
Too expensive! Thanks for the suggestion.
Old 22nd June 2012, 11:03 PM   #23
Well, it costs approx. 80 Euro.
Old 22nd June 2012, 11:06 PM   #24
Yes.. but it can save you more in crossover parts cost (..a LOT more).
(..and make for an easier design as well as the option for a MUCH lower freq. response - depending on the woofer.)
Old 22nd June 2012, 11:07 PM   #25
Yes I see your point ScottG. I will consider your suggestion.
Old 22nd June 2012, 11:53 PM   #26
Inductor is offline Inductor  Portugal
Inductor's Avatar
Good point to considerer. Better to spend 40.00+ of driver parts than of better caps or extra components. Valid consideration, Starre if you think it will sound better.
Working with a 4" Midrange as a tweeter certainly will not be the standard. But who knows what can be done.
Is your listening room narrow or large?
Old 23rd June 2012, 12:28 AM   #27
Inductor's Avatar
Interesting PeteMcK, I think the same, good value and easy to work with. Not decided if using sealed or BR box though...
To use sealed enclosure make sure to use an adequate driver... (who knows?).
Sealed or Ported Enclosure Calculator
Driver good for BR (SEAS CA18RLY nice in 32 L to 42 L) and quarter wave.
Old 23rd June 2012, 06:36 AM   #28
PeteMcK is offline PeteMcK
re: 'sealed or BR box' - BR, ~ 40L tuned to the low 40s....
(probably good in TL or MLTL too...)
Impedance varies with frequency, use impedance plots of your drivers and make crossover calculations using the actual impedance of the driver at the crossover frequency
Old 23rd June 2012, 10:06 AM   #29
Inductor: I used that calculator for CA18RLY and it said it was fine either way. Do you think the crossover for CA18RLY and 27TFF need to be complicated/expensive?
Old 23rd June 2012, 11:07 AM   #30
fatmarley is offline fatmarley  England
Going by an online calculator, the CA18RLY will work well in a 25ltr box (QTC = 0.7) with an f3 of 63Hz.
Someone over a the PE forum said that their old AR18 has an f3 of 62Hz but because of the high'ish Q design (QTC = 1 IIRC), they had a steep roll-off. I owned some AR18s a while back and thought the bass was really good, so the CA18RLY in a 25ltr box should be better (more accurate and go a bit deeper) but have less authority being a smaller driver.
IIRC the Seas 27TFF (or was it the 25TFF?) was used in the Proac Studio 100. I used to own those speakers and I thought they had a nice, crisp and clean treble.
With the crossover done right, I think that could make a nice combination.
What is most important when choosing driver?Hide this!Advertise here!
Midrange Driver QTC in 3-way system: Important? RalphL Multi-Way 34 22nd October 2011 11:41 PM
more important to match Q or box resonance when driver matching is less than ideal? wintermute Multi-Way 2 1st January 2005 07:23 AM
where is short wiring in an amp important/ not important ? sandro600 Solid State 5 4th April 2004 03:10 AM
Choosing a sub driver based on T/S... manxam Multi-Way 2 21st February 2004 10:16 AM
is driver spacing important ? busterno1 Multi-Way 12 9th February 2004 06:28 AM
