What is most important when choosing driver?
Old 22nd June 2012, 01:25 AM   #11
tvrgeek is offline tvrgeek  United States
When you say from scratch, do you mean to learn to design a speaker system, or you want to build an established design rather than assemble a kit?
Do you have any engineering background, but just not in speakers? ( would you understand what the S-plane is?)
Or do you just have a good ear and am ready to go insane like the rest of us? Either is fine, but it helps in what advice you should go looking for.
Don't waste big money on expensive drivers. Get half decent cheap ones and LEARN what to do with them. Zaph helps a lot in that. There are $1000 speakers out there with $10 tweeters.
Don't even have the slightest thoughts about something more complex than a two way.
Download WinISD and play with box parameters for different woofers. If you read Joe DeAppolito's book, you will understand what these parameters mean. If you have the technical background, read Linkwitz's WEB.
Build something. Listen carefully. Think. Make a change and think about what you heard. Think some more and make another change. Keep a notebook. Change only one thing at a time.
You might start with a well documented design so you have measurements and just focus on the crossover a few dozen times. Learn to listen, learn to measure.
Old 22nd June 2012, 04:16 AM   #12
samadhi is offline samadhi
"Don't waste big money on expensive drivers. Get half decent cheap ones and LEARN what to do with them. Zaph helps a lot in that. There are $1000 speakers out there with $10 tweeters."
Agreed, and don't spend too much time worrying about super low non-linear distortion (provided it's not a complete train wreck), smooth frequency response is more important.
Wide band soft cone drivers are easier to work with and are much easier for a beginner to get right. I wouldnt recommend hard coned drivers, or cones with a strong breakup of any sort for a first design.
Something like a Peerless HDS midwoofer with Dayton RS28F tweeter would be a perfect first project, with good enough drivers to compete with most any 2-way out there.
Old 22nd June 2012, 09:14 AM   #13
Starre is offline Starre  Sweden
tvrgeek, I have some engineering knowledge and I do not plan to use expensive drivers. I do not want to build an established design. Looking for a 2-way, yes.
Old 22nd June 2012, 10:29 AM   #14
chlorofille is offline chlorofille  Malaysia
chlorofille's Avatar
What's your max budget for the drivers?
Old 22nd June 2012, 07:39 PM   #15
I think I will use seas ca18rly as woofer.
Old 22nd June 2012, 08:27 PM   #16
fatmarley is offline fatmarley  England
Looks like a nice driver.
Old 22nd June 2012, 09:24 PM   #17
And for tweeter: Seas 27TFF
Old 22nd June 2012, 09:33 PM   #18
PeteMcK is online now PeteMcK
Hey Starre, that's close to the combo I'm using for my next 2 way, CA18RLY (Nice sounding driver) + 22TFF (yet to receive these), I think this combo will make easy to crossover & good sounding, excellent value speakers.
Impedance varies with frequency, use impedance plots of your drivers and make crossover calculations using the actual impedance of the driver at the crossover frequency
Old 22nd June 2012, 09:42 PM   #19
Interesting PeteMcK, I think the same, good value and easy to work with. Not decided if using sealed or BR box though...
Old 22nd June 2012, 09:55 PM   #20
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
funny, I change opinion every time I think about it
What is most important when choosing driver?Hide this!Advertise here!
Midrange Driver QTC in 3-way system: Important? RalphL Multi-Way 34 22nd October 2011 11:41 PM
more important to match Q or box resonance when driver matching is less than ideal? wintermute Multi-Way 2 1st January 2005 07:23 AM
where is short wiring in an amp important/ not important ? sandro600 Solid State 5 4th April 2004 03:10 AM
Choosing a sub driver based on T/S... manxam Multi-Way 2 21st February 2004 10:16 AM
is driver spacing important ? busterno1 Multi-Way 12 9th February 2004 06:28 AM
