Tapered TL vs MLTL - Page 2 - diyAudio
Old 21st June 2012, 10:07 PM   #11
pkitt is offline pkitt  United States
If a tapered TL has a single impedance peak like you illustrated, it's had the life literally stuffed out of it with the result of absolutely no contribution from the terminus' output to the bass response. If you're going to do that, you might as well just make a big sealed box rather than wasting your time building a complex tapered line.
Paul
Originally Posted by RockLeeEV View Post
Hmm? While ther are different ways to tune, as far as I can tell a Tapered TL should have an almost entirely damped lower impedance peak:
resulting in a shallow knee response profile like this:
An ML-TL will have a dual impedance peak
resulting in a more efficient, but sharper knee response profile like this:
The different between the two alignments results in a different amount of overlap between the terminus' and driver. The Tapered TL will have an excursion profile like this, where the line controls the driver lower in frequency:
while the ML-TL will have an excursion profile like this, where the port starts to act against the driver:
While I don't want to make claims of what's "right" and "wrong", i think that if the tapered TL (quarter wave) is getting the same response profile as the ML-TL (bass reflex) then you're probably modelling the Tapered TL... unusually.
Old 22nd June 2012, 12:22 AM   #12
the model still shows 3db of lift over a wide bandwidth. The F3 compared to a sealed box of the same size goes from 90hz to 52hz, and the F10 also drops slightly from ~33hz to ~30hz. The stuffed line still shows reduced excursion near its tuning.
Beyond that, the more shallow rolloff can sound better in some rooms and placements vs a flat ML-TL, due to room modes and pressure vessel gain causing peaking in the 20hz to 50hz region, which is a big factor in slow perceived bass.
If you ask me, bothering with any kind of resonator - line or port or passive radiator - is a waste of time. Use 3 or 4 carefully placed, small, equalized multiple sealed 15" subs for accurate bass in real rooms below 100hz. Go dipole or cardioid above 100hz.
Old 22nd June 2012, 12:28 AM   #13
No it doesn't. It has the same double peaks at lower stuffing densities.
It has to have double peaks for the line output to be significantly useful.
rgds, sreten.
Old 22nd June 2012, 09:27 AM   #14
picowallspeaker's Avatar
I must give credits to Paul ( thanks ) for having inspired me to build
my first tapered TL . It was a lot of work , about two years ago , and the speakers are still in my room , so it mustn't be that bad
I didn't put any stuffing inside
but much use of constrained layers damping ...and when I found a pair
of rotten Altec Mod.300 and repaired the foam , those gray woofers
really match the vinyl gray finish I adopted
Tony
Old 22nd June 2012, 11:52 AM   #15
cs is offline cs  United Kingdom
In my modelling, the MLTL was uniformly stuffed at 0.5 lb/cu ft, but the TL was only stuffed in the first half (from driver end) of the line at 1 lb/cu ft. The second half of the TL was left empty. I used a 5:1 taper, starting at 3.4*Sd and ending at 0.68*Sd. The driver was a 6.5" poly-coned unit from HiVi, although that may not be my final choice.
The attached plots show freq resp, impedance and cone excursion for each configuration. If I stuffed the whole of the TL, then the plots were very similar to yours, with very little bass reinforcement.
Chris.
Old 22nd June 2012, 02:26 PM   #16
What I've found to be almost always the best stuffing configuration for the best overall system response coupled with optimum port/terminus air velocities and driver excursion considerations, is this: In an ML-TL only the first 50% of the line's length contains stuffing, while in a tapered TL it's typically the first 60-67% that's stuffed. If stuffing is added beyond those lengths, the detriment to F3 is usually too severe for whatever is gained anywhere else. Increasing the stuffing density, however, for the lengths I mentioned will provide improvements in response smoothness with a much smaller detriment to F3. Just a whiff of stuffing in the terminus of a tapered TL will completely kill its output. In a tapered TL I will use a larger taper ratio before increasing stuffing density or length because the larger taper also minimizes response ripples (I never use a taper ratio smaller than 10:1).
Paul
Chris.
Old 22nd June 2012, 02:35 PM   #17
I agree with you on one point; I would never recommend a TL of any kind for strictly subwoofer use, which is what you're really talking about in your last statement. It's a waste of time, but if someone wants to, that's fine. But since I don't use, want or need a subwoofer, all of my designs are for full-range systems, usually 3-ways. A TL is inherently a 4th-order system and its response shape can be tailored to have 4th-, 3rd- and 2nd-order rolloffs below F3, with obviously different effects on its impedance profile and how much bass contribution is provided by the port or terminus. Since there is very little, if any, content in most music (excluding special effects for movies, for instance) below 30 Hz, much less at 20 Hz, I consider it waste of abilities to force a 2nd-order rolloff because the improvement provided below 30 Hz is wasted, while at the same time, there is less output above 30 Hz where there is actual content to be heard.
Paul
Old 22nd June 2012, 03:42 PM   #18
mondogenerator's Avatar
interesting. I always wondered what was the difference between a MLTL and pipe shaped Reflex....Im hesitant to say there isnt one, since Im no expert, but It makes me wonder...
How many of those 80's/90's 'tower reflexes' actually stumbled upon MLTL operation.
I used a taper ratio of 20:1 on the basis that in a reflex system the 'rule of thumb' i know is a min vent area of 1/7th Sd, which is what I have used in several reflex designs (eg 5" woofer, 2" ID vent).
Balancing the things I must do, with the things I'd like to do...This is a skill (or a luxury) amongst many that I do not possess.
Old 22nd June 2012, 03:55 PM   #19
It's just the air that acts as a 'mass ' that is coupled to the membrane till
a certain frequency , beyond that limit it's too slow to follow the higher cycles .
Old 22nd June 2012, 04:05 PM   #20
I'm sure there have been a lot of accidental ML-TLs created over the years, and I'm just as sure most of them will be quite a bit removed from having an optimal performance that can be achieved by proper location of the port. I've used taper ratios from 10:1 to 26:1 with good success.
Paul
fine tuning of tapered TL...can i do this??? mondogenerator Multi-Way 6 8th December 2009 06:05 PM
Do TL lines need to be smoothly tapered? GuyPanico Subwoofers 5 16th April 2005 09:01 PM
Calculating bends in a tapered TL bwbass Multi-Way 12 5th February 2005 09:58 PM
TL tapered design help/comments sunil Multi-Way 10 14th September 2004 03:45 AM
TL: coupling chamber vs. tapered line fortyquid Multi-Way 21 1st September 2003 11:03 AM
Copyright 1999-2017 diyAudio
