Advice - Replacement drivers for Castle Chester speakers
Old 23rd September 2012, 06:01 PM   #31
R.I.P.
A 1/4 wave cabinet that worked fine with the original driver unstuffed, still
had boomy bass completely stuffed with fibreglass with the new driver.
rgds, sreten.
Old 23rd September 2012, 06:04 PM   #32
speakerman19422 is offline speakerman19422  United States
speakerman19422's Avatar
What size driver and crossover point?
0 Phase Constant Voltage Series Crossovers.
1/4 W T-lines for Satellites and Subwoofers
Old 5th January 2013, 08:45 PM   #33
padman is offline padman  United Kingdom
Try morel caw638 and scanspesk d2905
Old 23rd January 2013, 07:30 PM   #34
rgds, sreten.
I would suggest using low density polyurethane foam for the damping material.
Approximately 60% in the first third of the line length. Reducing the foam to 40% in the middle and about 15-20% in the last section of the line. Place the foam in the line between the cabinet walls and not up against them.
A free flow of air must occur in the line.
I would be more than happy to send you an email of the many examples I have.
Fiberglass is very reactive and does act as a no pass filter in T-lines if heavily stuffed.
Many commercial designs do use the foam.
Old 24th January 2013, 01:55 PM   #35
chefsinc is offline chefsinc  Australia
chefsinc's Avatar
Originally Posted by 5th element View Post
You know I'm sure I've seen a basket design that looks like the rear of that before, specifically the casting around where the screw holes/flange are, it isn't Audax, but I cannot quite remember what, either that or I am remembering incorrectly!
They look like older Focal carbon fibre drivers. i had a pair with papercone that had nearly exactly the same shape basket. i saw some on ebay USA last year if your lucky.
Old 8th July 2013, 08:15 PM   #36
bug2k11 is offline bug2k11  United Kingdom
Finally got round to fitting the replacement drivers I picked up last year!
Just a bit of routing of the recess and the enlarging the mounting hole a little, the new Seas CA18RLY fits fine.
Also cleaned off the original dark stain from the cabinets and just used a clear danish oil to finish them, an improvement I think.
Haven't wired up the crossovers yet of run them yet, I'll get that done and compare the response with standard drivers later this week.
Old 26th January 2018, 10:19 PM   #37
markitzero is offline markitzero
How did the replacement drivers turn out? I have the same speakers with the same issue.
Advice - Replacement drivers for Castle Chester speakersHide this!Advertise here!
Castle Harlech S1 drivers memu51 Multi-Way 7 8th July 2016 06:50 AM
Crossover in Castle Trent speakers NTS Multi-Way 19 24th April 2015 11:35 AM
Replacement Tweeter for Castle Trent LightHeist Multi-Way 23 11th November 2013 05:55 PM
Drivers for S1 Castle Harlechs memu51 Multi-Way 0 20th February 2010 11:11 AM
