#21 |
I used the Dayton Audio DATS tester with the driver clamped upright on a bench (there was a couple of metres of free air around it).
There seems to be quite a few drivers with 177mm outside diameter. |
#22 |
#23 |
You know I'm sure I've seen a basket design that looks like the rear of that before, specifically the casting around where the screw holes/flange are, it isn't Audax, but I cannot quite remember what, either that or I am remembering incorrectly!
What the hell are you screamin' for? Every five minutes there's a bomb or somethin'! I'm leavin! bzzzz! Droggon Attack! |
#24 | |
frugal-phile(tm)
The manufacturers data is (almost universally) done using LEAP or LMS at much higher driver levels -- which, unless the driver has flat T/S curves, means a different set of numbers, sometimes dramatically so. dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#25 |
the SEAS CA18RLY might be suitable:
H1217-08 CA18RLY
Impedance varies with frequency, use impedance plots of your drivers and make crossover calculations using the actual impedance of the driver at the crossover frequency |
#26 | |
As Planet10 (Dave) says, the Chester is a paper cone.
![]() Quote:
I stand corrected. Crossover suggests about 0.9mH inductance (Le) to me at a wild guess.
Good Night, and Good Luck. Best regards from Steve in Portsmouth, UK. |
#27 |
I think the woofer is an Audax that is no longer available. The center of the back plate looks similiar to the Audax drivers I used in the early 80's. They made a lot of drivers.
0 Phase Constant Voltage Series Crossovers. 1/4 W T-lines for Satellites and Subwoofers |
#28 |
I've picked up a pair of these Seas Prestige H1217-08 CA18RLY
I've measured them with the Dayton Audio DATS and these are the paramters for each: * Manufacturer: Seas * Model: H1217-08 CA18RLY * Piston Diameter = 125.0 mm * f(s)= 44.41 Hz * R(e)= 6.04 Ohms * Z(max)= 28.37 Ohms * Q(ms)= 2.647 * Q(es)= 0.717 * Q(ts)= 0.564 * V(as)= 24.860 liters (0.878 cubic feet) * L(e)= 0.92 mH * n(0)= 0.29 % * SPL= 86.72 1W/1m * M(ms)= 10.93 grams * C(ms)= 1.18 mm/N * BL= 5.07 * Manufacturer: Seas * Model: H1217-08 CA18RLY * Piston Diameter = 125.0 mm * f(s)= 44.41 Hz * R(e)= 5.99 Ohms * Z(max)= 29.82 Ohms * Q(ms)= 2.526 * Q(es)= 0.634 * Q(ts)= 0.507 * V(as)= 24.860 liters (0.878 cubic feet) * L(e)= 0.90 mH * n(0)= 0.33 % * SPL= 87.25 1W/1m * M(ms)= 10.93 grams * C(ms)= 1.18 mm/N * BL= 5.37 Original Castle mid/bass drivers: * Manufacturer: Castle * Model: Chester * Piston Diameter = 125.0 mm * f(s)= 71.33 Hz * R(e)= 5.49 Ohms * Z(max)= 59.38 Ohms * Q(ms)= 6.439 * Q(es)= 0.656 * Q(ts)= 0.595 * V(as)= 10.250 liters (0.362 cubic feet) * L(e)= 1.00 mH * n(0)= 0.54 % * SPL= 89.43 1W/1m * M(ms)= 10.27 grams * C(ms)= 0.48 mm/N * BL= 6.21 * Manufacturer: Castle * Model: Chester * Piston Diameter = 125.0 mm * f(s)= 66.62 Hz * R(e)= 5.55 Ohms * Z(max)= 63.98 Ohms * Q(ms)= 5.847 * Q(es)= 0.555 * Q(ts)= 0.507 * V(as)= 11.420 liters (0.403 cubic feet) * L(e)= 0.85 mH * n(0)= 0.58 % * SPL= 89.74 1W/1m * M(ms)= 10.57 grams * C(ms)= 0.54 mm/N * BL= 6.65 Measured a little different to the published data, but as some have said may be due to the levels used to test. I'll get the cabinets modified to fit them, be interesting to see how they measure with the existing crossovers. |
#29 |
Note that the cone masses are similar, so the differences in Vas and Fs are very mutual. Also the lower BL of the Seas driver probably indicates more excursion, but with lower sensitivity. The x/o looks fairly standard and may work well with treble L-pad adjusted. My limited experience of putting higher Vas and lower Fs drivers into tuned 1/4 wave boxes is not good, a serious case of one note bass resulted. But I guess you'll have to suck it and see. rgds, sreten.
There is nothing so practical as a really good theory - Ludwig Boltzmann When your only tool is a hammer, every problem looks like a nail - Abraham Maslow |
#30 | |
Many claim good results with fiberglass. Many old articles in books and magazines of it being to reactive compared to wool and low density polyurethane foam.
| Crossover in Castle Trent speakers | NTS | Multi-Way | 14 | 3rd January 2013 03:06 PM |
| Replacement Tweeter for Castle Trent | LightHeist | Multi-Way | 15 | 24th May 2012 12:06 AM |
| Drivers for S1 Castle Harlechs | memu51 | Multi-Way | 0 | 20th February 2010 11:11 AM |
| Castle Harlech S1 drivers | memu51 | Multi-Way | 2 | 27th January 2010 06:33 PM |
