| Home | Forums | Articles | Gallery | Blogs | Register | Donations | FAQ | Calendar | Search | Today's Posts | Mark Forums Read | Search |
Thread Tools |
#91 |
I suggest that you get a copy of the latest Customs rule book relating to Baggage-it's available at any decent bookshop. You need to know the rate of import duty applicable on such shipments and add it to the cost and freight. I imported a passive radiator some years ago via sea mail from Lambda Acoustics in the US it took about 4 months, reached without a scratch(double boxed)
#92 |
why 4 months????
...still looking for the holy grail. |
#93 |
Surface mail from Florida to the nearest port, by USPS, then by ship to either Bombay or Madras and then surface to Bangalore..I thoght four months was fast! I also got my Welborne Labs chassis that way. This works ok if the value of the shipment is low( and it wont hurt too much if damaged), not otherwise!
#94 |
MDF has two varieties available in the market. Exterior grade is better than interior grade but more expensive. As navin rightly suggested u can use marine ply of high quality then u can get better performance than MDF for subwoofer, But it is extremely expensive. Now it is ur choice of quality to cost, because quality is never available cheap.
#95 |
Mahendra
Namskara( as we say here in Bangalore)! We all look forward to the benefit of your experience on this forum. Regards George |
#96 | |
today I am firming in my belief that a 18mm skin that is well barcd and damped can provide a decent cabinet. on the other hand I prefer no cabinet at all hence i am trying to design a WAF friendly dipole sub using 2 x 12" (DV12) per channel. in fact after rading SL's website I am also considering a 2 way sub where a corner loaded sub operates below 40Hz avoiding room nodes.
#97 |
Dear Navin,
Can u find 18mm/15mm HDF easily. If yes or with any particular dealer then please let me know. It is nice to use HDF because easy to work than Marine plywood. Mahendra Palesha |
#98 |
Jalaram in Prabhadevi carries it. you will find jalaram on the road between siddhi vinayak temple and kaboothar khanna.
#99 |
Sai
Check stryke audio, they have a preorder special on 12 and 15 inch sub drivers made by TC Sounds, one of the most respected mfrs of sub drivers. I am ready to set up a listening session next weekend-Dec 6/7 at my place. Ajju what do you say? Anyone else from Bangalore?After I hear from you guys I will give some ideas... George |
#100 |
Thank You
| Thread Tools | |
| Indian PA pro here? | mhtplsh | Multi-Way | 0 | 6th December 2008 02:49 PM |
| Indian makers? | sagar | Parts | 8 | 11th July 2008 08:55 PM |
| I need help from indian members | mikelm | Everything Else | 1 | 31st December 2004 06:41 AM |
| An Indian Hi | Technobel | Introductions | 1 | 10th June 2004 10:33 AM |
| Page generated in 0.10302591 seconds (82.41% PHP - 17.59% MySQL) with 11 queries |
