What would be the effect if 2 identical drivers are ...?
Old 13th October 2003, 05:42 AM   #1
Lito is offline Lito
Default What would be the effect if 2 identical drivers are ...?
What would be the effect if 2 identical drivers are connected in parallel but one of the drivers has its magnet orientation in reverse. Would 'nt they move acoustically in phase but electrically out of phase. Would they still benefit from the advantages of push-pull drivers?
Old 13th October 2003, 10:42 AM   #2
blank527 is offline blank527  Netherlands
Send a message via MSN to blank527
You could also reverse the pole of one the two speakers, same effect.
They still benefit push pull configuration.
Greetz,
Remco
What would be the effect if 2 identical drivers are ...?Hide this!Advertise here!
Two identical drivers HogieWan Multi-Way 3 12th December 2005 09:10 PM
Two identical drivers in one enclosure: Implications dumrum Multi-Way 3 31st March 2004 09:14 AM
moving drivers closer together will it effect xo busterno1 Multi-Way 1 30th March 2004 10:58 AM
effect of reorientating baffle and drivers? leadbelly Multi-Way 15 1st February 2004 04:26 PM
Effect of multiple drivers on ideal box volume hellomynameiswill Multi-Way 6 1st August 2001 03:26 PM
Copyright ©1999-2017 diyAudio
