First OB with vintage Seas
Old 22nd October 2012, 09:42 PM   #31
boris81 is offline boris81  United States
I ran into a similar problem with woofer sensitivity. 4 woofers wired in serial-parallel is not a good idea for OB. Since I am doing a multichannel-amplified project so I added an extra amp channel. 2 amp channels each driving a pair of speakers wired in parallel will give you a good boost in sensitivity. Of course you need to make sure the amps can handle the lower impedance.
Old 23rd October 2012, 03:21 PM   #32
zmyrna is offline zmyrna  United Kingdom
After giving it a good rethink,
I am moving towards active.
At least for the bass section.
nanoDIGI from miniDSP should work for me.
It is a 1 digital in, 4 digital out DSP.
Ultimately I can use a nuForce or Wadia power DAC for the upper section,
and my Tact digital amp for the bass.
I will see how the 4x10"s behave in that set up first.
Old 23rd October 2012, 10:37 PM   #33
DrBoar is offline DrBoar  Sweden
DrBoar's Avatar
measurments of those old Seas drivers
Vintagehifi.dk • Vis emne - Seas 25TV-EW TS och frekvensmätning
Vintagehifi.dk • Vis emne - Seas 21TV-EW Thiele-Small och Frekvens
Old 24th October 2012, 06:30 PM   #34
Thanks for clarifying series/parallel SPL issue.
@DrBoar
Thank you so much for the measurements. For some reason I was unable to find them on my web searches. 25TVs seem to be less efficient than I have assumed. On the positive side, they have arguably the ideal qts for open baffle. I wonder whether it will be possible to get enough LF dynamics by feeding them enough power. That is what I will try to find out next. Low mms is making me hopeful.
We should start a blackcone fan club.
Old 6th April 2013, 06:47 PM   #35
Default MM OB bass: still not happy
here is another prototype.
3 way active with miniDSP nanodigi.
CO points 250 and 3000, LR4 and EQ.
waveguide experiments on M and T.
MM topology for bass.
moving from 4 way to 3 way was a step backwards.
in an active OB set up like this (similar to SL and JohnK designs) 3 way is not optimum. SL and JohnK think it is because of dispersion problems at the CO point bw M and T.
I suspect there might be another component. narrow M baffle means we need EQ at the lower end of M. and I think EQ at that area might be negatively effecting the upper end of M (1000-3000hz).
in my next prototype I will be crossing the 8" cone to a neo8s around 1k.
another problem area is the resonances in the bass section, even with steep active CO and EQ.
so no wings or h frame in the next project. it will just be 4 10" woofers on a small square baffle. I think those W have enough excursion and the bass will be enough with active and EQ.
Old 13th May 2014, 04:18 PM   #36
I am ready for my next project.
Please help me select one of the following designs (all active CO with miniDSP) :
Option 1
(4 way)
>5000hz B&G Neo3 open baffle
800-5000hz B&G Neo8s open baffle
100-800hz 2x Seas 21TV-EW open baffle
http://vintagehifi.dk/forum/viewtopic.php?f=565&t=2622
<100hz 4x Seas 25TV-EW ripole
http://vintagehifi.dk/forum/viewtopic.php?f=565&t=2609
Option 2
(3 way)
<800hz GPA 416-8B sealed box
add subs if I move to bigger home
So the basic Q here is which low-mid section would better match the dynamics of planar highs.
I already have all the drivers and amps and the miniDSP (nanodigi).
Old 14th May 2014, 12:05 PM   #37
Here is a graphic representation of the two projects in my mind.
As you see, upper two ways (>800Hz) are identical for both.
The difference is in the low mid-bass.
And the question is, which low mid-bass option would be more dynamic to match the planars.
Old 16th May 2014, 08:02 AM   #38
DeonC is offline DeonC  South Africa
DeonC's Avatar
My vote is for:
Originally Posted by zmyrna View Post
Option 2
(3 way)
But put the Neo8 upright, not sideways. If sealed you will need a sub without a doubt. The GPA 416-8B is a low Q driver, so sealed it will have almost no bass. Port it and even then you might need a (very good!) sub.
Deon
I don't suffer from insanity. I enjoy every minute of it.
Have a look at my favorite thread: Interesting YouTube video clips
Old 16th May 2014, 10:55 AM   #39
Deon, thanks for your response.
Planar section of the speaker will be modular and will be optimized later on.
I will experiment on neo8 and neo3 with orientation, foam pads and waveguides.
Let's leave that discussion for now.
The subject of my recent post is matching planars with cone drivers.
I have presented two options:
One is high(ish) xmax drivers on open baffle with equalisation to combat OB cancellation.
Second is high SPL driver in sealed box.
First would be a good match for openness, and second for dynamics probably.
I am considering trying the sealed box option first because it is more straight forward.
I was hoping that I could do without subs because I do not even have the space for them.
(I have a pair of Faital Pro 18" woofers begging to be turned into subs though)
I should run the winISD to see if a bit of bass boost would be enough with the sealed box.
Old 3rd June 2014, 12:36 PM   #40
Okay,
Here is the latest design.
Crossover points likely 200 and 1000Hz.
Neo8S will have Raal foam pad treatment for vertical dispersion.
Option of adding supertweeter and monopole subs later.
For my little room, I am hoping to have enough bass with DSP dipole correction though.
First OB with vintage SeasHide this!Advertise here!
S11 OB - Revisiting Desktop OB design using Seas 8" and Tang Band Full-Range gainphile Multi-Way 28 27th May 2016 09:13 AM
OB with vintage Seas and Behringer Inuke DSP zmyrna Full Range 2 23rd April 2012 10:36 AM
OB for vintage Philips drivers Calamaro Multi-Way 6 12th October 2010 02:13 PM
Confused for OB! German vintage... Visaton B200... sure newer isn't better, but... drec Full Range 3 14th November 2006 04:36 AM
Vintage OB Drivers inrank Full Range 5 31st August 2006 06:43 AM
