Senior Project Build Thread
Old 29th September 2012, 05:35 AM   #21
Silent Screamer is offline Silent Screamer  Australia
Did you use any accoustic dampening material inside (dont see any internal shots)?
Old 29th September 2012, 06:12 AM   #22
kctess5 is offline kctess5  United States
No I didn't. Damping is not usually used with this sort of design as far as i can tell
Old 29th September 2012, 06:53 AM   #23
Ok I could be mistaken but I thought I recalled seeing a thread where they stuffed heavily towards the tight side and slowly decreased as it widened out but I could be getting mixed up with something else.
Old 29th September 2012, 07:00 AM   #24
Usually people don't stuff PA subs, mostly because it reduced output in exchange for slightly lower linear distortion and depth extension, which in PA is not a worthwhile tradeoff for many apps.
Old 29th September 2012, 07:16 AM   #25
Fair enough it might have been home theatre use where there would be some room gain, not outright SPL. How about some kind of anti resonance coating on the outside?
Old 29th September 2012, 07:35 PM   #26
I will be putting duratex on it. There is also internal bracing to reduce resonances
Old 30th September 2012, 01:43 AM   #27
Can't do much more than that... Seems like you have done all that could be done.
Old 8th November 2012, 02:56 AM   #28
I will do another update soon but long story short I have all 4 subs done. I am in the process of switching to the mains now
Here's a video I made for MIT admissions:
https://www.youtube.com/watch?v=BOwhWyn5ymE
Old 15th December 2012, 09:49 PM   #29
Another update. Once again I will do a more in depth write up soon but for now this will have to suffice. I now have all the stuff in the video done and almost one more main speaker.
https://www.youtube.com/watch?v=AIgY99MDAqI
In other news: I GOT INTO MIT!
Old 15th December 2012, 11:58 PM   #30
speakerdoctor is offline speakerdoctor  United States
R.I.P.
Congratulations! Now, do Amar Bose one better!
"It's all about the music!"
Senior Project Build ThreadHide this!Advertise here!
Senior Project Tube Preamp JRiggles Tubes / Valves 9 22nd February 2011 02:55 PM
aikido build thread- nate Tubes / Valves 1 27th February 2009 06:01 AM
New Project Build Thread ryoung Multi-Way 5 19th April 2008 02:15 AM
25 W Amplifier for Senior Project, due Friday Cyguy84 Class D 20 26th September 2007 09:47 PM
My senior Design Project Deltat Chip Amps 17 26th April 2005 08:53 PM
Copyright ©1999-2017 diyAudio
