Kord Vulcan - BM220 / D2008
Old 3rd June 2012, 09:17 PM   #1
inrank is offline inrank  United Kingdom
inrank's Avatar
Default Kord Vulcan - BM220 / D2008
A new project-
I previously had a pair of Kord Tornado speakers here-
Volt BM220DS + D2905/9300 - Kord Tornado
With a Volt BM220DS/D2008 tweeter (and D2905/9300 upgrade).
I managed to find a pair of just as rare Kord Vulcan speakers.
These appear to have the same drivers, with a slightly different crossover.
When I first got them-
Beauty and the Beast by hoopsontoast, on Flickr
The Veneer was peeling off, so thats the first bit.
Stripped-
Kord Vulcan by hoopsontoast, on Flickr
Veneer started-
One almost done-
Kord Vulcan Cabinet by hoopsontoast, on Flickr
Using Iron on Real Wood Veneer, with solid 3mm Walnut strips and 3mm Cork for the baffles.
The main difference is the BM220'DS' in the Tornado had a coated plastic cone, where as the BM220'DS' in these has a uncoated paper cone.
Any idea if this is a re-cone, as they should be from the same era (Circa 1981)
Tornado Crossover-
C1 = 2.2uf
L1/L2 = not marked
C2 = 4.4uF
R = 2.2 Ohms
Vulcan Crossover-
C1 = 4.7uf
L1/L2 = not marked
C2 = 10.0uF
R = 2.2 Ohms
Quite a big difference between the two. Looking at pics of the Tornado, the Coils look the same size on the Vulcan, relative to each other and the other components.
Old 11th January 2013, 09:19 AM   #2
iep is offline iep  United Kingdom
I think I just bought these speaker on ebay possibly from the guy you sold them to! You noted something in your post that I think I can explain.
You mention that the bass driver is a paper cone affair rather than the plastic cone on the Tornados. That is because it is not the BM220DS that you list in the post. If you check your own photo, it is actually a B220DS. This was a pulp paper cone derivative of the volt 8" design intended for use in P.A. applications (most recent and near identical version is called the BM220.1).
Apparently, your man at Kord had a listen to it and preferred it to the BM220DS in the Vulcan. It's near identical to the BM220DS except that the paper cone cause the freq response to become a bit lumpy after 2KHz. Apparently though, this did not bother the designer and he opted to use it anyway.
Either way, looking forward to taking delivery of them and trying them out for myself.
iep
Old 11th January 2013, 10:16 AM   #3
Sorry, just spotted that the photo I referenced is not in this post. I actually saw it in another forum with duplicates of the photos you show here. The photo I mean is this one where you can see the model number as B220DS:
iep
Kord Vulcan - BM220 / D2008Hide this!Advertise here!
Sachico vs Vulcan Thump660 Full Range 4 19th October 2011 05:30 AM
Volt BM220DS + D2905/9300 - Kord Tornado inrank Multi-Way 11 24th January 2011 12:43 PM
Vulcan or Sachikos? bigfishe Full Range 5 27th December 2010 07:44 PM
Vulcan Channel Meld LikaComet Construction Tips 24 22nd November 2009 07:03 AM
Volt BM220.8 audio_hobbyist Multi-Way 3 1st March 2007 12:05 PM
