Hi.
I own two Linn Klouts and i want to build two ways speakers using ESS Heil tweeters and EMS B15EX woofers. My Klouts accept Linn active cards but designed for Linn speakers. Is there a way to use Linn active cards or i need to use an external electronic crossover. Crossover frequency need to be 1000hz. Best regards.
That's was my first idea but it's the advisor from the store where i got the woofers vho said i should go active. Linn 2 way active cards suppose to cut at 2.8khz, far from the 1000hz he recommended.Regards
Wouldn't it be simpler to sell the Linn Xover bits and either DIY a 2 way xover that gives you the levels, frequency of xover and slopes you want, rather than kludge in something else?
