Need 8" woofer for 3 way design
Old 1st June 2012, 06:39 PM   #1
CCU is offline CCU  Denmark
Send a message via MSN to CCU
Default Need 8" woofer for 3 way design
Hi everybody
I'm looking for some 8" woofers for my new project. a 3 Way WWMTMWW.
I would love to use the Scan-speak revelator, but they are to expensive.
I'm currently looking at the SB acoustics woofer and the Peerless HDS nomex.
Leaning most towards the SB acoustics.
What woofer would you recommend? If not one of those two, which would you suggest in the sub 100 euro range?
Thanks in advance
Old 1st June 2012, 06:47 PM   #2
Zuhl is offline Zuhl  England
Zuhl's Avatar
SEAS L22:- H1252-08 L22RNX/P
Old 1st June 2012, 06:58 PM   #3
Why do you recommend that particular driver? personal experience?
Old 1st June 2012, 07:31 PM   #4
pkitt is offline pkitt  United States
Since you don't want to spend the money for an SS woofer, the SB Acoustics is a really good choice. I've used both (SS-8857) in TLs and while the SS woofer has a larger Xmax and can play a little louder, the SB 8-incher comes very close in performance. Also, if you go to philharmonicaudio.com, you'll see Dennis Murphy's offerings, two of which use the SB woofer and the other an SS-8851 8-incher (for which I designed the TL enclosures for Dennis). I used the SB woofer in a 3-way, the Sonatello, with it mounted in a tapered TL (see attached image).
Paul
Originally Posted by CCU View Post
Hi everybody
Thanks in advance
Old 2nd June 2012, 07:14 AM   #5
navin is offline navin  India
navin's Avatar
Send a message via MSN to navin Send a message via Yahoo to navin
Originally Posted by Zuhl View Post
SEAS L22
What about the Wavecor SW223? I know it is listed as a subwoofer driver but If you are crossing over sub 200 Hz it should work fine.
The other option would be the Peerless HDS models (835026 or 830869) or one of the Dayton models.
...still looking for the holy grail.
Old 2nd June 2012, 07:38 AM   #6
ScottG is offline ScottG  United States
The Usher 8137A, or rather its all black version (USHER 8136-K):
www.audax-speaker.de/index.php?module=shop_articles&index[/url][shop_articles][action]=details&index[shop_articles][category]=12&index[shop_articles][data][shop_articles_id]=117
You can see Zaph's testing of the original 8137A here:
http://www.zaphaudio.com/8test/
(you'll need to cut and past the url's.)
Not only can it perform at low freq.s in a relatively small enclosure (..all else equal), it has some of the lowest non-linear distortion of any driver below 200 Hz. Those particular factors in combination, even with the price increase, make it one of the best (..if not the best) solutions in your price range. (..the Peerless has even better higher order distortion performance at lower freq.s, but won't give the same amount of extension near the average for a comparable enclosure volume.)
perspective is everything
Old 2nd June 2012, 09:04 AM   #7
Zuhl's Avatar
Yes. I'm using them in a three way and the bass is as taut and detailed as anything I've heard.
Old 2nd June 2012, 09:30 AM   #8
fatmarley is offline fatmarley  England
I decided on THIS because I wanted something that can work in a smallish sealed box (I don't like ported bass)
Old 2nd June 2012, 09:54 AM   #9
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
ScSp have a couple interesting glassfiber coned 8" in the discovery series
thou not sure how they achive 92db for the 4ohm woofer
might be a mistake, or very optimistic, but I dont know that
actually, theres also a nice looking new mid with glas cone and phase plug, and with ist highish sensitivity, a light coating might do good
Old 2nd June 2012, 01:49 PM   #10
Michael Chua is offline Michael Chua  United States
Michael Chua's Avatar
I have both the Usher 8137A and the Peerless HDS 830869.
Personally, I prefer the Usher. It's more Dynamic and "Ballsy". Exactly the kind of sound I like. Lots of detail in the Upper Bass Region (80-200Hz).
Brings back memories of the SS Revelator, but that was years ago when I last heard them.
The Peerless 830869, by comparison, is more "Polite", for lack of a better term. To be fair, I need to work on this Peerless again. I think I'm not getting the maximum potential out of it.
ampslab
Need 8" woofer for 3 way designHide this!Advertise here!
4" jordan plus woofer design norman bates Full Range 13 21st May 2010 06:11 PM
"Box" design and bracing for open baffle woofer array ryoshu Multi-Way 0 17th August 2008 07:07 PM
shoehorn a 15" woofer / design help mercury_marine Subwoofers 13 28th January 2008 01:31 PM
Tiny 2-way design w. 6.5" woofer Lomax Multi-Way 6 20th May 2003 08:15 AM
Copyright ©1999-2017 diyAudio
