Old 28th May 2012, 07:04 PM   #1
Default Tannoy red original or recone?
Good day, please help to identify if this Tannoy RED 12 were recone or not (pictures enclosed)?
The colour of cones is suspiciously black...
Old 28th May 2012, 11:15 PM   #2
You really need a dedicated Tannoy site, but FWIW I don't suspect a recone,
but the centre dust caps look to me far too shiny, like the whole driver has
been treated with some sort of spray, (Including the front gasket as well),
not good at for the treble response that should pass through the dustcap.
I would tread very carefully.
rgds, sreten.
There is nothing so practical as a really good theory - Ludwig Boltzmann
When your only tool is a hammer, every problem looks like a nail - Abraham Maslow
Old 28th May 2012, 11:28 PM   #3
VaNarn is offline VaNarn  Australia
I agree,the cone has been coated with something like wood stain.It is unlikely to have any sonic effect if this is what has been used.
Old 28th May 2012, 11:48 PM   #4
looks like they'e been coated with Dammar
Impedance varies with frequency, use impedance plots of your drivers and make crossover calculations using the actual impedance of the driver at the crossover frequency
Old 28th May 2012, 11:51 PM   #5
Hi, very bad for the centre dustcap, rgds, sreten.
Old 29th May 2012, 12:03 AM   #6
devilsindetails's Avatar
+1 The treble unit...the very heart of the Tannoy Dual Concentric no longer can breathe because of that coating...someone has suffocated it!
I have yet to see any problem, however complicated, which, when you looked at it in the right way, did not become still more complicated. (Poul Anderson)
Old 29th May 2012, 12:08 AM   #7
The cone thickness of the Tannoy is approx. 0.46 mm.A treatment such as Dammar or an elastic PVA compound will have a noticeable effect on such a relatively thin cone and it is something that I would avoid unless I was certain that the outcome lead to an improvement.
Old 29th May 2012, 04:48 AM   #8
Thanks for information...wery helpfull. If orange part was coated than drivers are dead? Will be no treble at all?
Old 29th May 2012, 06:04 AM   #9
limono is offline limono  United States
I guess they rather sound better than before after coating if this was danmar indeed . Thats what Troels found out threating his pair. If you want them to flip and earn the money maybe it's not the safest bet but for your personal enjoyment I'd take them in heart beat . If the orange dust cover is sealed with danmar than remove it and enjoy a better speakers altogether. Good luck , wonderfull speakers danmar or not.
Old 29th May 2012, 01:19 PM   #10
Tannoy Monitor Red Crossover questions glenz75 Full Range 1 13th January 2012 04:14 PM
Tannoy Monitor Red Response? Tenson Multi-Way 0 27th August 2010 02:48 PM
Tannoy monitor RED 12'' cabinet marin_iskra Full Range 4 11th November 2008 09:51 PM
Single Tannoy monitor red as a sub? Brisso57 Subwoofers 6 29th September 2008 04:40 PM
Single Tannoy monitor red as a sub? Brisso57 Full Range 0 28th September 2008 01:21 AM
Copyright ©1999-2013 diyAudio
