Old 10th October 2003, 01:50 AM   #1
getafix is offline getafix  Philippines
getafix's Avatar
Default help interpreting graph
plugged some figures in Unibox and came out with this graph for a vented enclosure:
forever dreaming of a better set-up...
Old 10th October 2003, 04:11 AM   #2
You have two Tang Band 4 inchers in a ridiculously large enclosure, tuned far too high. That is why you have the huge peak just before cutoff.
Since there are 28.3 Liters in 1 Ft³, this enclosure is 5.3 Ft³! That is big enough to fit a 15 incher into, instead of two 4 inchers.
I suggest either a sealed box with 13 Liters, or a ported box with 19 liters tuned to 50 Hz.
See if the dark blue line doesn't look better. That is, a flat line all the way down, untiil it turns downward for the cutoff.
"A friend will help you move. A really good friend will help you move a body."
-Anonymous
Old 10th October 2003, 04:50 AM   #3
getafix's Avatar
i tried to change the volume in Unibox... didn't know that I could do that ...
anyway, the graph looked much better... is this basically the shape that one has to achieve whenever designing vented or sealed enclosure?
Old 10th October 2003, 09:10 AM   #4
just another
wintermute's Avatar
That looks much better. I usually play around for a while until I get something pretty flat, with as low a 3db point as possible without compromising the flatness too much. It's interesting to change things like the port length, or box volume, just to see how it afects things.
Have fun
Tony.
Old 10th October 2003, 09:51 AM   #5
Vikash is offline Vikash  United Kingdom
diyAudio Moderator Emeritus
Vikash's Avatar
Don't forget that appropriately coloured red line cutting through the graph! This show that the drivers have reached max linear excursion (xmax) at ~175Hz. So at 80w input, flattening out the bottom octaves by changing box volume, tuning etc. makes no difference.
Alter the power handling figure until you find a point where the red line does not intersect with the black line within the required range (or using the second Unibox graph might be easier - peak cone excursion graph).
"The human mind is so constituted that it colours with its own previous conceptions any new notion that presents itself for acceptance." - J. Wilhelm. (But I still think mine sounds better than yours.)
Old 10th October 2003, 12:45 PM   #6
just another
wintermute's Avatar
Good point Vikash. As I found out before, that point can be surprisingly low too!
Old 12th October 2003, 12:52 AM   #7
getafix's Avatar
thanks for the info... i'll try to modify some of the figures later
interpreting max. values listed in datasheet kathodyne Tubes / Valves 7 4th July 2008 06:49 PM
Preamp help – Interpreting the results. GeeVee Solid State 16 10th January 2008 12:05 PM
Interpreting SOA graph for IRF640/9640 steevo Solid State 1 26th April 2007 07:45 PM
Interpreting R-Theta's HS ratings? dantwomey Pass Labs 5 11th November 2002 03:30 PM
Interpreting Electronics Schematics Super Everything Else 39 22nd September 2001 03:53 PM
Page generated in 0.08620 seconds (75.51% PHP - 24.49% MySQL) with 11 queries
