Old 28th May 2012, 12:39 AM   #1
Default Gap between coil and pole piece
I just bought a pair of 15" coaxial speakers with 4" voice coils. I notice that the gap between the coil and the middle pole piece section (containing the horn mouth of the tweeter) is about 2mm, which I think is rather large. There is no rubbing and the cone seems to be centered.
Would this large gap pose problems?
Old 28th May 2012, 01:00 AM   #2
devilsindetails's Avatar
Pics?
I have yet to see any problem, however complicated, which, when you looked at it in the right way, did not become still more complicated. (Poul Anderson)
Old 28th May 2012, 04:07 AM   #3
Tomom is offline Tomom  Australia
If sensitivity of speaker is to spec, why would that pose a problem...
Old 28th May 2012, 05:43 AM   #4
VaNarn is offline VaNarn  Australia
A precision machined magnet assembly can have a clearance of around 0.16mm although if a high power/long throw coil is used,a 0.2mm spacing between the voice coil former and the centre pole could be expected.As Tomom says,if the sensitivity is o.k.then there is not a problem with the speaker.Copy paper is 0.1mm thick;you could double check your clearance estimate by sliding a few strips into the gap as an indication
Old 28th May 2012, 06:30 AM   #5
Pics would be helpful as would type, manufacturer and any other specs on the driver itself. Vintage? or New?, for example.
Old 28th May 2012, 06:51 AM   #6
Actually I just found out that the gap narrows down at some point. What I thought was the centre pole piece is simply a piece of metal for the horn throat that is glued down on top of the centre pole piece. Tight clearance is not required for this piece. Case solved.
The coaxials are from some chinese factory, I purchased them via alibaba. http://huiyinaudio.en.alibaba.com/pr...l_speaker.html
They seem pretty well made other than from the fact that the transition from the non-moving part of the coaxial horn to the cone part of the coaxial horn isn't perfect. The solid throat ending juts out at about 2mm above the cone. I will make another thread asking for some ideas to tackle the diffraction issues from this, plus piccies.
Vented pole piece and phase plugs Stanislav Multi-Way 13 5th July 2010 01:20 PM
Voice coil gap tightness breez Subwoofers 4 14th November 2008 09:12 PM
pole piece material? tuneman Multi-Way 17 5th August 2006 02:32 AM
XXLS - No Pole Piece Vent mike.e Subwoofers 7 7th January 2005 09:49 AM
Pole Piece Q ALFIrE Multi-Way 3 24th December 2004 06:09 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
