What would be the smallest ported box volume you would recommend for the Seas W17EX-002? Tuning frequency recommendations too please?
What crossover frequency would you use when paired with Seas T25CF-001? |
#2 |
Zaph|Audio A better cheaper Seas driver combination for a 2 way, for the reasons explained in the write-up, and his tests. rgds, sreten.
There is nothing so practical as a really good theory - Ludwig Boltzmann When your only tool is a hammer, every problem looks like a nail - Abraham Maslow |
#3 |
because it's such a low Q driver, (Qts = .26) any vented box is going to have an element of EBS alignment; How low you want to go will determine box size & tuning. 12L @ 45Hz will give an F3 of 48 Hz; 15L @ 43 Hz wil give an F3 of 43Hz.
The driver will need a notch at just under 6Khz, 2Khz looks to be a good xover point
Impedance varies with frequency, use impedance plots of your drivers and make crossover calculations using the actual impedance of the driver at the crossover frequency |
#4 | |
#5 |
Well follow that kit, the only way to make a big difference in cabinet volume is to make them sealed and use a subwoofer. Do you have link to the original design ? rgds, sreten.
#6 |
Odin MK3
that'll give you the notch required, but even if you halve the volume, the MTM is using 2 drivers to make up the drop-off in bass. With a single driver you'll need to deal with this using judicious tuning & baffle step compensation.
#7 |
The kit was a MTM design and I plan to use this to make 4 individual speaker and buy another 2 tweeters. i.e. single woofer and tweeter in each.
Let assume 12L as the box volume. |
#8 |
Can you do rough schematic of the crossover? Not sure what you mean by a notch at 6khz. Do you mean a LCR filter. thanks...
#9 |
Its a very tricky driver to use in a 2 way due to distortion caused by the large peak at 4KHz to 5kHz. D3 at ~ 1.5KHz, D4 at ~ 1.1KHz and D5 at ~ 0.9KHz will all be bad, indicating you really need a x/o point lower than around 1KHz. http://www.clofis.nl/brochures/seas/E0010_W17EX-002.pdf The seas graph is in a sealed 12L box, note the amount of BSC needed. I'd use both drivers and the tweeter in a 3 way. rgds, sreten.
There is nothing so practical as a really good theory - Ludwig Boltzmann When your only tool is a hammer, every problem looks like a nail - Abraham Maslow Last edited by sreten; 28th May 2012 at 12:10 PM. |
#10 |
re:'rough schematic' - well, you can use the schem on the SEAS site, with the value of L1 doubled for a single driver; then you need to adjust L1 for baffle step, and adjust the attenuation on the tweeter (R2) to compensate.
Yes, notch = LCR filter
| Seas Excel W17EX-C W17-001 | kramster | Swap Meet | 1 | 26th October 2008 03:31 AM |
| WTB: Seas W17EX-002 | PHilgeman | Swap Meet | 0 | 3rd February 2006 05:30 PM |
| Want To Buy: Seas W17EX-002 | PHilgeman | Swap Meet | 0 | 7th September 2005 07:55 PM |
| Wanted Seas W17EX-002 | PHilgeman | Swap Meet | 0 | 26th July 2005 03:58 PM |
| FS: Two Seas W17EX-002, consecutive serial numbers... | ScottRHinson | Swap Meet | 1 | 4th April 2003 02:02 PM |
| Page generated in 0.10312 seconds (100.00% PHP - 0% MySQL) with 9 queries |
