having spent too much time playing music & not listening, last night, with the help of messrs Rammstein, Sabbath, Handel, Cream & Tull with a few bottles of Monteith's Black Beer, gave my CA18RLYs a pounding. measured them this morning, q&d results:
data sheet,#1, #2 Fs 42, 49, 49 Qt, .47, .49,.49 Vas, 32, 34, 27 They seem to be consistent drivers, variation in Vas is probably due to my technique, I find that when I Blutak a coin to the cone, different positions give different results. They're good sounding drivers & destined for a pair of 38L cabs I have lying around, tuned to the mid 40s... they'll be used as .5 helpers with my ER18RNXs for a while, but I think ultimately will make a good 2 way by themselves
Impedance varies with frequency, use impedance plots of your drivers and make crossover calculations using the actual impedance of the driver at the crossover frequency |
#2 |
I'd typically choose to attach the weights to the dustcap edge where it will be the strongest, and close to the voice coil. Coins are good because their official weights are public knowledge, but if you have scales you could try using only blu-tak as it is less likely to detach on its own.
| CA18RLY or SB17 ? | percy | Multi-Way | 17 | 4th May 2013 04:47 PM |
| My first 3-way + measurements | rinx | Multi-Way | 12 | 19th December 2012 12:29 PM |
| ca18rly vs. ca18rnx in sealed box | ermes | Multi-Way | 1 | 25th November 2010 12:16 PM |
| are these measurements okay? | eitanwaks | Multi-Way | 3 | 23rd March 2010 07:32 PM |
| different measurements | resident | Tubes / Valves | 4 | 17th April 2005 09:04 PM |
