New waveguide for 1"+ tweeters - Page 2 - diyAudio
Old 27th May 2012, 12:49 PM   #11
Inductor's Avatar
Originally Posted by samadhi View Post
It needs to be turned sideways for use with a 5" woofer, such that the rectangular face makes driver spacing too high.
It's obvious, and I agree. Many designs have also large space between drivers. They (manufacturers) don't come with a lot of designs every year, much less for new waveguides/horns, the SEOS project being an exception for the last couple of years. When one comes out it's new but has some flaws. Visaton is known for being good but not a good example of perfection with some very good (read the best) products.
Old 27th May 2012, 02:34 PM   #12
pguerin is offline pguerin  France
The main reason i defend this product are that it is aviable for a price i am willing to pay for an item for experimentation, Troels WG who probably are better are NOT aviable for such a price
Maybe they're just a copy of the Pyle PH65 or MCM 54-580
I've inquired the price, i was quite surprised, four times the price of the the previous references.
I own two TW034, by the way if you use them without wave guide, you must add a notch filter f : 10.7 khz, Q:1, -3db (RCL 5.6 Ohms, 2.2 mF, 0.1 mH) because of their rising SPL curve. The use of a wave guide creating a flat SPL curve prevent tu use this notch filter.
Old 27th May 2012, 06:01 PM   #13
FE3T is offline FE3T  Norway
Originally Posted by Pascal GUERIN View Post
Maybe they're just a copy of the Pyle PH65 or MCM 54-580.
Nope, the WG`s you mention are made for use with a troat with brass treaded inserts for accepting compression drivers. those who have used them with dome tweeters have made substantial moods to make them work.
Troels WG are made for the TW34XO and the Visaton are made for a few of their domes. and will only need mods if you want to use them with CD`s
Thanks a lot for that info, it migth come in handy of any of my 4 TW34XO will end up being used without a WG.
Old 27th May 2012, 06:56 PM   #14
In a German magasine they have crossed it at second order 2Khz (6.8mF, 15 mf, 0.33 mH).
I havent tried to filter the tw034 it so lower, in my system I use now second order,
(3.8 mF, 0.15, 12 mF) fc is arount 4500 kHz.
Feedback welcome concerning TW034 crossover and measures
With wich speaker are you planning tu use de TW034 ?
Old 28th May 2012, 04:06 AM   #15
They will most probably end up with bastardized bassmids made by mixing and matching certain baskets reconed with other than the manufacturers intended parts, i prefer to not say more at this point, since i migth wanna buy more rawmaterial and dont need competition for the parts at the prefered sources. After all, i belive i am not the only one who would like to try out this idea, or would like to try to partially DIY a couple of drivers.
Old 28th May 2012, 10:55 AM   #16
Visaton-s 'waveguide' is a 15cm circle. Seas has a 10cm DXT, Monacor WG-300 is a 17cm unit.
This profile is more similar to a good studio-monitor waveguide, should give a 130-150deg. nominal coverage in the tweeters passband. No more mushroom-cloud looking horizontal dispersion. Shame they put it on a big rectangle. Makes mating to a 5-7" a pain due to wider baffle than necessary. An 8" is quite directional by 2kHz, but can this device hold pattern till 1,5kHz to mate with an 8" - guess no. Anyone got some polars?
Old 28th May 2012, 01:13 PM   #17
Pic taken from the Visaton Studio 1 page
Old 28th December 2012, 11:57 PM   #18
Seems like a round version of the Visaton WG has surfaced
Link
Old 29th December 2012, 01:03 AM   #19
pos is offline pos  Europe
pos's Avatar
Should be interesting to test with a 1.5" compression driver (used in a "tweeter" range...)
Old 29th December 2012, 11:04 AM   #20
mondogenerator's Avatar
I noticed these WG before. The one aspect that prevented me trying them is the 20mm domes im using with my AL130 woofers.
The rectangular guide, used vertically, could have an arc cut from the bottom edge to decrease driver spacing.
Balancing the things I must do, with the things I'd like to do...This is a skill (or a luxury) amongst many that I do not possess.
Using reticulated foam with waveguide loaded soft dome tweeters Westy37 Multi-Way 12 4th October 2011 03:14 AM
1.5" Ciare MT320 Mounted in a Modified 12" PE Waveguide opc Multi-Way 2 14th February 2011 04:35 PM
Simple DIYable Waveguide testing (dome tweeters) dlneubec Multi-Way 3 14th October 2008 04:10 PM
FS: Seas 27TBCD-DXT - new waveguide tweeters Tenson Swap Meet 3 7th July 2008 11:53 PM
15" Volt Radials R3803 60 each, Seas DXT waveguide tweeters, 500VA Toroids ShinOBIWAN Swap Meet 23 2nd April 2008 06:41 PM
Copyright 1999-2017 diyAudio
