#41 |
WMTMW is a MTM (mid-tweeter-mid) with woofers above and below, then add stereo subs to that. Ends up as a 4 way system, which a 8x2 minidsp can handle.
If you're going to go with closed boxes, as opposed to horns or open baffle, I think they should be extra large and stuffed, as to act as close to infinite baffle as possible, basicly low Q. I also prefer a minimum baffle, aka Vandersteen. Transient correct - look into Thele and Dunlavy designs......much easier to do these days with the dsp. |
#42 |
would this work if I already have a sound card in my laptop:
Behringer: XENYX 302USB where I could plug the calibrated mic into this and this into my laptop via USB? |
#43 |
Turbodog,
Do you have any plans for such a layout as you described? |
#44 |
I can't tell if the XENYX has phantom power or not. Do you know? If it does, it will be fine.
As for the WTMW, I've heard some nice ones, but can't help you at all there as I have no build or crossover experience (important!) with these. I keep it simple and classic.
Take the Speaker Voltage Test! |
#45 |
Hey Michael,
I looked on the Behringer site and it does have phantom mic power. Check this out though: Check out these new horns - Very Impressive That just looks classic to me...I could get excited about something like this. Maybe add a woofer and a tweeter and WOW. Is that not beautiful? What do you think, Sir? |
#46 |
The comments are in doubt if that great looking kind of horn is the best approach compared to the current state of the art in horn design. This could be interesting for your project: Horns (don't know the price) |
#47 | |
Active high dynamics/SPL & high performance loudspeaker system for my living room…! Ground Sound High-end 3-way active Avalon look-alike WATT puppy clones? Dunlavy Audio Labs Signature SC-VI loudspeaker | Stereophile.com DIY Audio 3-way reference project?? Transient correct / square wave reproduction: Can't Reproduce a Square Wave. Interesting, simple and cheap-ish waveguide/horn plus DSP project: S15: Econowave DSP - a Constant Directivity vs Dipole study |
#48 |
Oh and just my personal point of view, from a non expert.....I like horns/waveguides and would consider using them in a design, but feel that they inherently lack "correct" dynamic/impulse response compared to a transient perfect design using cones/domes/ribons/planars and the correct crossovers. Especially the horn subs.
Open baffles are also very popular and I've built open baffle subs myself. While I see the appeal, I'm not too crazy about the back wave and the level of cancelations occuring, and inefficency. Why not infinite baffle, or more practically, an extra large enclosure (Qts < .5, or as practically near Qtc as possible) with lots of damping material, and 1st order high pass with the dsp? Last edited by turbodawg; 22nd June 2012 at 03:11 PM. |
#49 |
Sorry, meant: (Qtc < .5, or as practically near Qts as possible)
| What Does Fostex "Rated Input" and "Music Power" | mark02131 | Full Range | 5 | 13th October 2012 05:18 AM |
| Fostex 10F3 "Solo 103" speakers | jmillerdoc | Full Range | 8 | 25th February 2010 06:19 AM |
| 70cm tall, 3 way, diy speakers based on 10"/4"/1" japanese ken brown drivers. | facundonu | Multi-Way | 34 | 9th March 2009 04:59 AM |
| Fostex "rated input" and "music power" | hugz | Full Range | 12 | 16th March 2006 04:33 PM |
