has anyone ever done this or would it be possible. if i decide to do this i had thought about making a convex top and bottom, so there is no flat spaces at all inthe tube. building my flat baffles out of MDF and fiberglassing them to the tube. i figure should be a very sound eclosure, but i may be wrong. any help would be appreciated
if only it looked as good as it sounds |
#2 |
I can't offer you any advice, but this guy...
http://www.speakerbuilding.com/content/1019/ ... may a two-way out of a ceramic sewer pipe! You may encounter some similar problems. Possibly. Nice one, David. |
#3 |
I'm not sure what you mean by fiberglassing. Is that how you intent to eliminate the air spaces between the MDF and the tube or just as an adhesive?
#4 |
You should take a peak at Aaron Gilbert's Emerald Towers. Made from Cubicorn tubes and covered with green velvet, hence the name. Sounded pretty good too.
If you don't measure, you don't know. |
#5 | |
But, what kind of imaging dyou get with the drivers that high in the cab? |
#6 |
He used 5 for a home theator set up. See post #30 in the link in my message.
#7 | |
You have posted a link to an attachment, not a thread |
#8 |
I probably misunderstood. I was assuming you were putting the sonotube inside an MDF enclosure. Creating an elliptical interior is a worthwhile goal. To eliminate the parallel surfaces of the top and bottom just put a sand filled sock in the bottom and tie it down with a zip tie to an eye screw.
(sock idea courtesy of Steve Margolis aka ) 7V ) |
#9 |
i just plan to use the fiberglass to secure and close the gaps from the mdf to the sonotube. i do not plan to crush the tube at all. i have seen someones line array where they crused part of the tube to make it flat. i dont really want to do that, i would just prefer to keep everything round. only reason for me choosing sonotube is cause i can get it locally, dont want to pay the herendous expense of shipping Cubicon
Chris
#10 |
Sony Str-de875, thats the one with the pretty blue DTS light!
Stare at that big blue LED too long and you'll go cross eyed... Its a good unit for the $$$ spent, pity about the matching 5 disc carasole DVD player...peice of junk(DVP nc600)skip skip skip skip skip is all it does!(even on brand new never been played disc's)
A Menace to Sobriety! |
| W18E001 + 27TDFC bookshelves, need design help (sonotube?) | thadman | Multi-Way | 7 | 18th April 2012 10:48 PM |
| design floorstanding 2way with Neo3 in dipole and Fr125 in TL | Henkjan | Multi-Way | 19 | 31st July 2010 08:38 PM |
| Building Custom 2way Towers, design questions | sonenelson | Multi-Way | 4 | 9th June 2009 12:36 PM |
| Help on 2way DIY Enclosure | pcyl | Planars & Exotics | 2 | 10th February 2009 12:31 PM |
| Page generated in 0.12005 seconds (81.04% PHP - 18.96% MySQL) with 11 queries |
