Need OB advice
I am in the market for dipole speakers. So far my list includes the Sunflower Redux, the AV123 x statik and the Selah 3d. It appears that the Selah is the best and most expensive.
Please rate in order of highest sound quality first as I have never heard any of these and would be buying them without audition. Are all 3 of these considered audiophile quality WRT performance?
If there are any I have not mentioned that should be included please do so. Thanks so much.
size, budget, etc
There are other good choices of similar size and price. What are your goals, size restrictions, budget?
Size isn't too much of a problem since I have a dedicated room and the WAF is NA.:D
I'd like the speakers to be no larger than 5 ft tall the budget is $2k complete. Since I have a sub (Velo servo) They don't need rock bottom bass but should get down to mid 40's. I listen to jazz, rock and some classical. I hope that helps.
Administrator
Joined 2004
If you make a list, it will be by the price list. If you put better drivers you will have a better speaker if the designs are good ...
I'd go to the Sunflower Redux because it is a full DIY.
I have others suggestion :
Acapella NEXTSEAS W22NY001 +
It is full DIY and the sound will bee not so far to the Salah 3D
Jerome the Acapella looks good but I am not sure those drivers are still available.
I am sure the Acapella Next drivers (except the tweeter) are still in production :cool: ! If not, Troëls will not keep this construction at his first page and i would not talk about it.
You can can find the specifications here: SEAS EXCEL
You can buy them here:Madisound Speaker Components: distributor of loudspeaker drivers and parts for speaker builders.
Note the T29CF001 must be replace by the T29CF002 (1700$ total cost of drivers) but I think you can use instead the cheaper T25CF001 (1200$ total cost of drivers)
that is exactly what I meant (The tweeter) Thanks, the cost is very similiar with a Selah design.
