#61 | ||||
![]() Other approaches can work ok, especially in heavily-treated rooms were one hears relatively more direct sound. But none of them seem to do as well as the above-outlined approach. Quote:
IMO, the most pressing shortcoming of DSP crossovers today is that too much boost will lead to digital clipping. Not an issue for most uses, but for extreme Linkwitz Transforms for small subs, or dipole bass compensation, it can be an issue. Quote:
Serious Audio Blog |
#62 | |
Only one that was designed not to be an easy load. A raw driver can be far worse than a well designed system with proper impedance compensation. High capacitance is the tough part. Rising inductance as you say, less so. |
#63 |
#64 |
Hi OnAudio,
Excuse me for being a little late joining the party, but here is my two cents worth - One issue that I am aware of that effects the quality of audio reproduction is that due to group delay, which has been documented and confirmed as being an undesirable byproduct of Xover filters. Group delay varies in a Xover as function of its crossover frequency, its Q and order. And from recent work by people like Geddes, it seems that our sensitivity to group delay is a function of frequency and also SPL. So from this, my choice of filter order would include group delay as well as all the other many parameters that affect the overall quality of reproduction. To show the variation in group delay between the various Xover filter orders, I’ve attached two sets of curves, one for even order and the other for odd order Xovers. All of the responses are from LR type filters. Of interest in the odd order Xovers is that minimum group delay is significantly affected by the polarity of the tweeter. The polarity of the tweeter in the even order Xovers is set to give a flat frequency response. One thing that stands out for me is that the 3rd order group delay with the tweeter polarity reversed is the same as that for the 2nd order Xover! So Why not use 3rd order instead of 2nd order? Another issue that comes to mind is that the LP and HP responses of a 2nd order LR Xover is –6.02dB down at the crossover, which gives perfectly flat on-axis acoustic summation at the crossover frequency, but only half the power. On the other hand, the summation using a 3rd order Xover gives a flat acoustic response on-axis, with only -3.01dB loss at the Xover frequency, thus providing no power loss. In my opinion, this is an issue that needs further thought. Regards Peter |
#65 |
Thanks PLB, lets assume one picks such a crossover point such that cabinet resonance fixes the power issue. Or picking such a point to cater for 200Hz room boom
#66 |
lots of phase rotation there PLB, makes for tiny sound and poor coherency between drive units ...
#67 |
Hi OnAudio,
"Thanks PLB, lets assume one picks such a crossover point such that cabinet resonance fixes the power issue" Do you have any suggestions for simulation software for that? Or that can accurately model the polar response? ![]() "Or picking such a point to cater for 200Hz room boom " A tweeter that can handle 200Hz? ![]() Regards Peter |
#68 |
#69 |
Agree PLB on both accounts ....
| advanatge of 1s order over 2nd or 3rd order? | Professor smith | Multi-Way | 149 | 23rd September 2010 04:43 PM |
| 1st order Passive Line Level Crossover + 2nd order Highpass? | alexclaber | Multi-Way | 11 | 4th January 2008 07:15 PM |
| deceptive perception ? 1st order-2nd order question | poldus | Multi-Way | 4 | 10th April 2007 11:58 PM |
| 2nd Order Tweeter + 3rd Order Woofer = OK? | Jay | Multi-Way | 3 | 12th September 2005 12:12 PM |
| 1st order ? L-R 2nd order? or transient perfect?? | Ken L | Multi-Way | 6 | 17th October 2003 04:22 PM |
