#221 | |||
Or are you referring to a 3rd driver filler approach or DSP approaches using non causal filters ? Quote:
As I was saying in another thread recently, above a certain frequency we have no ability to detect phase at all, (somewhere above about 1-1.5Khz) except by any amplitude summing changes it introduces or perhaps arrival time differences on impulsive sounds if the group delay is really bad. So if your crossover is well above this frequency and the amplitude response is flat, you're not going to hear the phase shift of the crossover per se, all you might hear is the group delay if it's really bad, or perhaps the filter ringing if it's really bad. A well designed 4th order or lower filter shouldn't have problems with either of these... Accurate square wave reproduction is one of those things I wouldn't even bother trying to measure or achieve, not when so many sacrifices must be made to come even close to achieving it. Ruining a lot of very audible parameters to optimise one virtually inaudible one is never a good idea IMHO.
- Simon Last edited by DBMandrake; 5th June 2012 at 06:32 AM. |
#222 |
- Simon |
#223 | |
Markus |
#224 | |
Transient Perfect Designer Two Way Then there are all the subtractive crossovers that are TP which are defined by HP= 1 - LP. These are generally asymmetric at for any order LP filter the HP section ultimately has a 1st order roll off. The inverse, LP = 1- HP is similar but the LP is ultimately 1st order. These are all casual and can be implemented using analog or digital approaches though some may not lend themselves to passive realization.
John k.... Music and Design NaO Dipole Loudspeakers. "We have no right to assume that any physical laws exist, or if they have existed up to now, that will continue to exist in a similar manner in the future." Max Planck
#225 |
isnt pre-ringing due to the type of feedback used in the filter cct? Effectively speeding up the rise time of the attack envelope, u essentially induce resonance? Ive studied this before...to be honest it put me off the whole topology, doesnt it erode the advantage of such filters somewhat?
It still amazes me every time I get something right |
#226 | |
The bird in a snow covered field can also be modeled . Last edited by OnAudio; 5th June 2012 at 03:15 PM. |
#227 | |
Markus |
#228 |
#229 |
There are a couple of "black holes" where relevant information gets lost and/or distorted. So current channel-based production techniques don't try to recreate a wave field like binaural recordings do because two-speaker stereo is inherently inadequate for such an approach. Even 5.1 or 7.1 multichannel is inadequate.
Markus |
#230 |
I am proposing that with proper speaker design, the lost information can be 'recovered'
| advanatge of 1s order over 2nd or 3rd order? | Professor smith | Multi-Way | 149 | 23rd September 2010 04:43 PM |
| 1st order Passive Line Level Crossover + 2nd order Highpass? | alexclaber | Multi-Way | 11 | 4th January 2008 07:15 PM |
| deceptive perception ? 1st order-2nd order question | poldus | Multi-Way | 4 | 10th April 2007 11:58 PM |
| 2nd Order Tweeter + 3rd Order Woofer = OK? | Jay | Multi-Way | 3 | 12th September 2005 12:12 PM |
| 1st order ? L-R 2nd order? or transient perfect?? | Ken L | Multi-Way | 6 | 17th October 2003 04:22 PM |
