Caps in x-overs - diyAudio
Old 22nd May 2012, 01:36 PM   #1
valvesound's Avatar
Default Caps in x-overs
A friend asked a question which I do not know the answer to, maybe someone here could help.
He has many Type X2 capacitors lying around and he wants to know if they could be used in an x-over. They are MKP (polyprop) and MKT (polyester) dielectric types. Is there a difference in a "normal" polyprop and a polyprop Type X2 typically used for mains suppression and filtering?
Old 22nd May 2012, 02:07 PM   #2
Inductor's Avatar
Yes, usually MKP are better and more expensive, used for high frequencies.
MKT are more used for lower frequencies or in parallel circuit with drivers, not as important duties and as replacements for old electrolytic caps. But you should adress each cap in special and it's characteristics relating with hi-fi.
AUDIO CAPS TEST by Tony Gee - The Netherlands
EDP Cool Jazz 2016
Old 22nd May 2012, 02:55 PM   #3
valvesound's Avatar
Hi Inductor, thanks for reply.
Maybe I put my question badly, but my question is not polyprop vs polyester. It is: Can Type X2 capacitors be used in an x-over or are there other influences the Type X2 construction might have on audio. Type X2 caps which are design for mains applications are packaged to be high voltage safe and fire resistant etc. Is there maybe "snubbing" effects that will prevent high frequencies from getting through the high pass filter? Is the Dissipation Factor as good as 'n "normal polyprop?
Old 22nd May 2012, 03:11 PM   #4
Inductor's Avatar
"Type X2 capacitors" meaning a crossing (line) capacitor tested to 2500V (...didn't know).
X1 (impulse tested to 4000 Volts), X2 (tested to 2500 V), Y1 (tested to 8000 V) and Y2 (tested to 5000 V).
EDP Cool Jazz 2016
Old 23rd May 2012, 12:02 AM   #5
AllenB is offline AllenB  Australia
They can be used, but there's no guarantee you'll find them an improvement on what you have.
Old 23rd May 2012, 12:15 AM   #6
Inductor's Avatar
Originally Posted by valvesound View Post
many... capacitors lying around and he wants to know if they could be used in an x-over.
I would not lose my time with used ones, probably if they are "shot" and out of spec. If new I certainly would compare them with standards (or best caps from the list) and would improve with matched pairs.
EDP Cool Jazz 2016
Old 23rd May 2012, 02:13 AM   #7
DavidL is offline DavidL  United States
Banned
Just replacing caps with other types without measuring the values is going to make the sound different. Some people consider this as "better" I just call it modifying the frequency response unknowingly.
Old 23rd May 2012, 06:28 AM   #8
valvesound's Avatar
Thanks guys for the replies.
These are unused caps which he has and he has measured them to make up a parallel bank to produce a value required for the filter. It is a new x-over for a new pair of speakers he built.
So the question is, is it worth the effort or are these Type X caps inferior?
Old 23rd May 2012, 06:35 AM   #9
I subjectively formed the opinion some time ago that I wasn't going to mess with them any more, but YMMV.
Old 23rd May 2012, 06:40 AM   #10
valvesound's Avatar
Hi AllenB, sorry but what does YMMV mean?
Branching x-overs Temporal Multi-Way 4 4th November 2007 10:52 PM
MTM X-overs. Tristanc1 Multi-Way 2 3rd March 2006 03:15 PM
x-overs Madmike2 Multi-Way 3 25th June 2005 11:42 PM
Active vs. Passive X-overs Pete H Multi-Way 60 7th June 2005 04:08 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd.
Copyright 1999-2016 diyAudio
