You can easily obtain around 2T in the gap if you reduce it to 1mm and max height around 6-7mm.But of course this is not what you will have in the airgap. My airgap has 1,3mm with a length of 10mm and a diameter of 40mm, and I have (measured, not guessed) 1,54T in the airgap.
