Project Ryu - DIY Field Coil Loudspeaker
Old 26th April 2013, 09:58 AM   #221
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
Originally Posted by Frank40 View Post
Yes.... please post a picture of your cone, I would love to see it
man, I need to build that chassis soon
Old 26th April 2013, 10:13 AM   #222
Hentai is offline Hentai  Japan
Very nice, I like the pattern.
Did you weight it? Hope the voicecoil/cone joining point is strong.
Old 26th April 2013, 10:48 AM   #223
Frank40 is offline Frank40  Denmark
Frank40's Avatar
Nice cones tinitus, like Hentia I like the patten to. Is that Kapton you use for coil former?
Will you make a short description on how you made it, always looking to learn new stuff.
Where did you get the pigytail wire?
Take care.
Old 26th April 2013, 07:20 PM   #224
I made this 'mold'
voice coil is put on the centre tap
and diaphragm/cone is molded directly on to it
if needed I can put on more reinforcement on the back
it was supposed to be a midrange only
didnt have ambitions for the heights
Old 27th April 2013, 01:28 PM   #225
Frank40's Avatar
Nice job, tinitus. It looks like you have treated some kind of cloth, is that correct and if so what is the base material.
Take care
Old 29th April 2013, 05:09 PM   #226
Frank40's Avatar
Got the field coils from Hentai today, he did a amassing job. I put on a basket and a cone just to see, it looks wild..Here is some pic's.
Next step is to design a strong basket for the unit.
Take care
Old 29th April 2013, 09:38 PM   #227
Glad you like it Frank. Yes it is serious audio there, looks very good. Can't wait to read about sound impressions.
Old 30th April 2013, 06:56 AM   #228
Dave Zan is offline Dave Zan  Australia
That looks like fun!
My respects for very impressive work by Hentai.
Serious postal costs too, I expect!
Best wishes
David
Old 30th April 2013, 09:34 AM   #229
Thank you David,
Postal cost can get high yes due to weight. On these it was about 100E.
Old 11th May 2013, 11:15 AM   #230
Frank40's Avatar
Originally Posted by tinitus View Post
hey, using a spider for the surround, thats clever
do they have them somewhat smaller ?
btw, I have a DIY cone I made using lighter foaming poly glue
I can post pics if interested
tinitus, you gave me a idea, thanks.....Using a spider could work if it was softer and airtight, I spend some time to figure it out how to losses up the addictive in the spider. I found that ammonia dose the trick, next step is to get it airtight. I found that latex milk dose contains ammonia and can seal the holes in the spider at the same time... and what do you know.... it's works beautifully. Took some pic's.
Project Ryu - DIY Field Coil LoudspeakerHide this!Advertise here!
First DIY loudspeaker project for LM3886 kiske1 Full Range 68 26th April 2012 03:27 PM
Open baffle field coil project jonjin Multi-Way 1 6th December 2010 11:19 AM
Has anyone DIY a Field coil? OzMikeH Full Range 18 16th November 2010 01:56 PM
field coil? otto88 Full Range 0 2nd October 2010 03:33 AM
What's a Field Coil Amplifier? krzanik Tubes / Valves 9 14th May 2005 03:22 PM
