#141 |
Here is a update on the wizzer/voice coil former. It went pretty well, it is durable for sure but for now I need to make a former a each wizzer. Hentai, I can try to make one with paper for you, but what kind of paper do you want to use.
#142 |
Hi Frank,
Looking good, looking good. How much does it weight? Good paper is that used for calligraphy, should be around 100-150g/m2 density, 0.2mm thick. Can you change the outer diameter to something bigger? |
#143 |
Hi Hentai
I am sorry to say that I had no luck in making a wizzer with paper, I only had silkpapaer so that is what I used. But I think if you are going to use paper it is best to use a positive and a negative form, under high pressure. The weight is 3.8 gr with the voice coil. I did a quick test and it relay works...There is plenty of energy in the high frequency range, a super tweeter for real. My guess is that it start a around 4-5KHz and up, but this is just by judgeing by ear. Here is some pic's: |
#144 |
Very nice Frank,
I understand about paper. Can you make it from this material but for specific voice coil diameter, length and whizzer diameter? |
#145 |
Hi Hentai,
Sure I can make a pair of wizzers for you. But sense you have access to Machinery, the best way is if you make a former and send it to me. You can make it of any kind of hard plastic or even hard wood, and if you make it your self, you decide the dimensions. On the other hand... if you like I can show you in more details how I make them, the hard point is to make the formers when you don't have the prober machinery. Once you have the former, there is relay nothing to it. |
#146 |
I apologize for intruding.
But where do you find a suitable selection of wire for VC? Very nice thread btw! Best I've seen for ages!
Theory and practice..... |
#147 |
For regular enamelled wire, check transformer winding supply houses.
Be CERTAIN to get "high temperature"wire, if possible "Class F/170 degrees Celsius" because nowadays thin wires often come in weak self fluxing enamel, which is designed to *evaporate* when hot. VERY bad in a VC. |
#148 |
I some one help me. I need a large spider for a 35.5mm voice coil but I can't find a dealer, I would like to finde one at around 120 to 150 mm.
#149 |
Speaker Replacement Parts - MAT Electronics
Here is some spiders and voicecoils.It seems you have to cut the hole to the right size for the voicecoil yourself. Bernt |
#150 |
Thanks Bernt
| First DIY loudspeaker project for LM3886 | kiske1 | Full Range | 68 | 26th April 2012 03:27 PM |
| Open baffle field coil project | jonjin | Multi-Way | 1 | 6th December 2010 11:19 AM |
| Has anyone DIY a Field coil? | OzMikeH | Full Range | 18 | 16th November 2010 01:56 PM |
| field coil? | otto88 | Markaudio | 0 | 2nd October 2010 03:33 AM |
| What's a Field Coil Amplifier? | krzanik | Tubes / Valves | 9 | 14th May 2005 03:22 PM |
