Looking for beta testers : VST plugin - bass correction for vented box
Old 19th May 2012, 12:04 PM   #1
ttmusic is offline ttmusic  France
Default Looking for beta testers : VST plugin - bass correction for vented box
Hello,
I have been looking at this forum from time to time and this is now my first post (feeling like a big dive !)
Some years ago I built a pair of Proac 2.5 clone and since that period I enjoyed learning loudspeaker & enclosure theory.
Even if I am found of analogue sound I see a good opportuniy of using computer as new degree of freedom to simplify loudspeaker enclosure design.
This is why I have developed a VST plugin to make active bass correction of vented boxes. The idea is not to take the environment into consideration but just the loudspeaker and its enclosure.
I have made some testing with my 2.5 clones and found good benefits (make them less boomy with better bass control)
I am now looking for some testers to confirm this tool could be useful & further developed.
As the correction algorithm is specific to each configuration some input data are required.
Here is a list of minimum requirements if you'd like to make a test:
- Computer with a media player compatible with VST plugins (like Foobar2000 or JRiver)
- Low range driver box configuration: Internal volume / Port(s) description (diameter / lenght / number) / Stuffing density evaluation (0 to 100%)
- Low range driver Thiele/Small parameters = Qts, Fs, Vas
Optional (and ideal): same as above + impedance curve of the low range driver (when set in the enclosure) and additional loudspeaker parameters = Re / Bl / Sd
Of course if you have 2.5 clones you only need the computer & one VST compatible media player.
I you are interested please send me an email with relevant data at fresponse@free.fr
Thanks for your help,
Thierry
Old 28th May 2012, 01:26 PM   #2
Hello again,
I add some information for whom who may be interested:
This plugin is based on the old idea of loudspeakers open loop control like for instance the 6th orders alignment initially proposed by Thiele.
The advantage using computer & plugin is that all kind of alignments can be easily achieved
The transfer function of the loudspeaker to be corrected is based on the classic Smalls model including different losses (port, internal damping, leaks)
For instance here are the compared transfer functions of my 2.5 clones and a classic 4th order Butterworth (with -3db at 20Hz)
and the correction that will be applied to the input signal to reach this Butterworth alignment
Finally here is snapshot of the very simple plugin control panel
Gain = to lower input level if corrected signal is bringing clipping
Type = choose one of the pre programmed alignment (Butterworth, Bessel, Chebychev with 0.1 to 3dB ripples)
Freq = targeted -3dB cut off frequency
Don't hesitate to contact me if you'd like to make a try with your own loudspeakers
Looking for beta testers : VST plugin - bass correction for vented boxHide this!Advertise here!
Looking for beta testers grenadier Everything Else 4 30th November 2011 05:23 AM
Chipamp.com is looking for Beta Testers JL889 Chipamp 29 17th November 2011 01:50 PM
In Bass reflex box (vented)-If I make smaller box than what consequences will I have? eliaselias_0 Multi-Way 6 3rd January 2011 03:49 PM
Help me getting the bass I simulated (Beyma 10G40 in vented box) jm_kzo Multi-Way 8 24th February 2009 08:56 PM
Copyright ©1999-2017 diyAudio
