Choosing wattage for woofer, midrange, & tweeter
Old 9th October 2003, 01:47 PM   #11
JojoD818 is offline JojoD818  Philippines
JojoD818's Avatar
You guys are right on the money, you have opened up my mind regarding the issue of speaker wattage. Ok, I'll forget that and look for the sensitivity of the drivers. I was invited to a showroom of a local speaker manufacturer and I'll be there on friday, at least now, I know what to look for and have the ability to listen to every part (woofer, midrange, tweeter) before I buy.
If you do have other words of wisdom, do's and dont's, I'll check up before I leave.
Best regards,
JojoD
Old 9th October 2003, 03:26 PM   #12
Bob2 is offline Bob2  Canada
JoJo
Rod Elliot describes matching speaker levels on his site.
http://sound.westhost.com/index.html
Check out the article on Bi-amping.
http://sound.westhost.com/bi-amp.htm
Bob2
Old 9th October 2003, 05:54 PM   #13
gary f is offline gary f  Canada
gary f's Avatar
A good article on power handling. Must read
http://sound.westhost.com/tweeters.htm
F
Old 10th October 2003, 06:49 AM   #14
navin is offline navin  India
navin's Avatar
Send a message via MSN to navin Send a message via Yahoo to navin
Originally posted by planet10
Good point... so the woofer should be the least efficient after you factor in BSC... since i'm mostly building bi-poles now i often forget about BS.
dave
given that BSC is 6db there are few cases where the woofer is not less efficient than woofers. yes woofers should be less efficient after BSC because padding a woofer could serverly affect the bass response of the woofer.
BTW with bipoles do you only bipole the woofer or the tweeter as well.
i am going from my memory (this is from the late 60s early 70s i think i did more speaker building from 72-78 than i do now)...the way music spectrum is broken is as follows:
about 50% below 300hz
about 75% below 2500Hz
about 95% below 10k
I think then AR came out with the 2x, 2ax, 3x series they based the power handling of their drivers based on the above. These speakers used a large woofer in a sealed box.
A decade or so later the DQ10 was also similary designed.
todays music (electronic) has a lot more energy at the freq extremes so these % will change a bit) I used western classical music as my bench mark (read as Bach, Chopin, Liszt, Smethana, Beethoven, W.A Mozart etc...)
boy, now I have gone and dated myself :-)
...still looking for the holy grail.
Old 10th October 2003, 07:22 AM   #15
planet10 is online now planet10  Canada
frugal-phile(tm)
planet10's Avatar
Depends what you are trying to achieve... i'm usually doing it with full ranges, with an optional super tweeter firing forward.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Choosing wattage for woofer, midrange, & tweeterHide this!Advertise here!
Midrange Crossover: Choosing the least of all evils? TheSeekerr Multi-Way 23 6th November 2008 09:20 PM
Help choosing a midrange up to $200/pair Mogar Multi-Way 10 30th November 2005 06:14 AM
Help choosing midrange driver Kittle Multi-Way 17 14th October 2004 07:21 PM
Help with choosing tweeter Mos Fetish Multi-Way 11 18th July 2003 03:01 AM
Choosing a tweeter for something like a proac 2.5 clone Ilianh Multi-Way 2 5th November 2002 02:17 AM
