Vifa p17wj-00-08 & D25AG-35-06 crossover.
Hi all,
As many would know, this is an old driver combination commonly used in the past.
I'm currently trying to design a crossover for a centre speaker with these drivers in an MTM horizontal config. (Tweeter mounted slightly higher than woofers)
The biggest issue I'm having, is trying to reduce variations in response horizontally. I realise this is inherently hard with MTM and I'm only doing this by ear. I've tried many variations by experimentation but just wondering if there is a trick to this? Or is there anyone that has done this before with these drivers? Basically I'm after crossover schematics that I can work from.
I've done heaps of searches but most of the crossover schematics seem to have gone.
I have found a couple but they are based on a single woofer in a vertical array.
Tweeter: http://www.wescomponents.com/datasheets/Speakers/Vifa/D25AG-35-06.pdf
Woofer: http://www.sea.vg/vifa/P17WJ-00-08.pdf
Anyone have any advice/links re the x-overs?
Any help will be appreciated :)
Joined 2008
You'll be fairly restricted in your crossover frequency, somewhere around 1700Hz in your case.
You'll want to get the phase difference between the drivers correct. Without this you kind of defeat the purpose of the MTM. A crossover specifically for an MTM wouldn't be the same as any other for the same drivers.
Did more listening/tweaking tonight and I'm certainly getting there.
I have seen the red spade audio link before, but the outlaw one is an interesting one. Osborn use this principle in their MTM centres too.
AllenB: Regarding xover point, if this helps, the tweeter is mounted higher than the two woofers and the acoustic distance (centre to centre) between the tweeter and either woofer is just under 130mm. Reason is the woofers are mounted on top of the frame of the tweeter so they can be closer. Doesn't that equate to a 2700Hz or less xover, or am I way off the track? Can I ask how you worked out 1700Hz? I think that's way too low for this tweeter anyway. :(
Thanks so far guys.
Joined 2008
I was probably just a little more conservative given that there are a few reasons why it is better to err on the low side with an MTM
By the way, that tweeter may not normally be crossed that low, but it could be if you were careful. It's also not a bad thing to keep crossovers low so they are less obtrusive.
Well, after reading this, I've now gone for a lower crossover frequency and it seems to have helped. :)
For now, I have settled on a single 0.82mH coil in series with the 2 woofers (connected in parallel).
For the tweeter, a 6.8uF and 0.82mH second order, with an l-pad after that consisting of an 18 ohm in parallel, and a 0.47ohm in series with the tweeter.
I've tried impedance equalisation as well as a second order slope on the woofers, but those all cause more horizontal variation. :confused:
The crossover frequency, at a guess is probably around 2kHz now, hope the tweeter can handle it. :D
Thanks.
Joined 2008
Have you considered this may be a phase issue.
There are tradeoffs between performance, distortions and the design goal. FWIW, I've done worse.
I have no doubt, its a phase issue, I'm assuming adding the extra capacitor is causing extra phase shifts which are not needed.
Anyway I'm having fun playing with it, if I can get it as good as possible, I'm happy. ;)
BTW: it was from reading you're thread on 'designing crossovers without measurement' which inspired me to get back into this. After the centre, I'm going to redo the crossover on my rear and front speakers too. (all my diy design from many years ago)
Joined 2008
Thank you shmb. I'm glad you're having fun with it. I'll leave you with this useful quote from speaker dave (just in case you haven't seen it).
speaker dave said:
One comment on tweeter polarity. i.e. choosing the right polarity. Try pink noise and sit fairly close (and on the intended listening axis). Reverse the polarity reapeatedly. The better position will make the sound more integrated and will make the units sound like they merge. With the wrong choice the woofer and tweeter are perceived as separate and distinct units.
...which can obviously be used for finding horizontal variations as well.
