IMF TLS 50 II driver replacements
Old 7th May 2012, 06:48 PM   #1
jeffrey88 is offline jeffrey88  Canada
Default IMF TLS 50 II driver replacements
Hi DIYA,
I acquired a fantastic pair of IMF TLS 50 II's recently and unfortunately some of the drivers have been replaced. They still have the original Audax 12X8 D25 tweeters and Kef B200 woofers, but the one midrange and the supertweeters are different. I'm looking for some input on what I can do about the midrange drivers because I am quite happy with the supertweeters. Unfortunately though the midrange was replaced with something that sort of was just slapped in and this needs to be remedied. It looks like the other midrange is still original.
If someone might be able to tell me what midrange the original driver is that would help.
Here are some pictures:
Honestly, I'm not sure which one is the original and which one is the replacement!
Thank you for any and all help.
Old 7th May 2012, 08:27 PM   #2
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Jeff,
Your pictures are linked to inside your gmail accout so we can't see them. If you could attach them to the forum (Go Advanced, Manage Attachments button)
The mids on there are Peerless K4040 (? not sure if the numbr without looking it up) in the cans, your pic will remind me of the superTweeter (Coles 4001?)
http://www.t-linespeakers.org/classics/TLS80/tls50.html
I've always wanted to get another set of TLS50s or 80s and do a rather "radical" upgrade. Replace the mid, tweeter & super-tweeter with a nice 3" full-range. On TLS80s, you could use the existing 4" cardboard cyclinder as an enclosure, on the TLS50 you'd need to fit one.
One would need to explore the possibilities wrt sensitivity and XO details, but the FF85wk would be at the top of the list.
One would need to redo the XO, either active or passive. The XO point between the B200 & the FR best choosen in relation to the box width / baffle step frequency (suggests 250-300 Hz).
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 7th May 2012, 08:41 PM   #3
Hey Dave,
Thanks for your response. I've updated the pictures so you can see them properly now.
As far as the XO's go they have already been upgraded as this was done when the supertweets were changed out. Unless of course there is more than one crossover in here!
Old 7th May 2012, 08:43 PM   #4
frugal-phile(tm)
planet10's Avatar
snatched from elsewhere
IMF TLS 50 II driver replacements-tls50-jpg
dave
Old 7th May 2012, 08:49 PM   #5
frugal-phile(tm)
planet10's Avatar
Both mids are replacement drivers (one looks to be a mid-bass out of an RS Minimus 7). Can you check to see if they are loaded into a cardboard tube?
The supertweeters are a variation on the theme of the Audax small inexpensive tweeter. Some of the Audax ones were quite good....
You can still buy new Coles 4001 http://www.coleselectroacoustics.com/drivece4100.shtml
http://www.falconacoustics.co.uk/dri...ive-units.html
dave
Old 7th May 2012, 08:55 PM   #6
I'm not currently at home with the speakers but I can certainly do that.
Thank you for your help Dave I really appreciate it!
Old 7th May 2012, 08:58 PM   #7
With regards to the supertweeters, I'm not so sure if I do want to replace those. I don't know a whole lot about replacing components in speakers, although I am experienced with Car Audio.
Anyhow, what I'm worried about is the crossover. I'm no electrical guy and unfortunately I think modifying the crossover is a bit out to lunch for me for now, unless I must absolutely do it for the mid-ranges and then in that case would be a worthwhile venture for the tweets possibly.
What's your thought on that? I do like the supertweets in there right now so I'm not sure if it would be worth it to change them out.
Old 7th May 2012, 09:11 PM   #8
KASUMI is offline KASUMI  United Kingdom
email Jerry at Falcon Acoustics he knows everything there is to know about IMF helped me with some TLS80's
Falcon Acoustics | The Leading DIY Speaker Parts and Kit Supplier since 1972
Old 7th May 2012, 09:12 PM   #9
Thank you so much for that Kasumi. That is very helpful.
Old 7th May 2012, 09:36 PM   #10
frugal-phile(tm)
planet10's Avatar
A significant part of Jerry's business is keeping a lot of these vintage projects viable.
Here is the original TLS50 XO
dave
PS: i find the top on the aforementioned FF85 better than any of the little "audax" i have tried (many)
IMF TLS 50 II driver replacementsHide this!Advertise here!
Krell ksa 100 ksa100 mkII mk II ksa50 50 GERBER gerbers pcb files project xslavic Solid State 10 1st August 2015 08:14 PM
Driver replacements hotscot Full Range 6 10th May 2011 06:17 AM
Multi driver TLs mashaffer Subwoofers 9 8th August 2006 01:21 AM
4-5" driver 50-10,000hz chuck55 Multi-Way 10 23rd June 2006 06:00 PM
