IMF TLS 50 II driver replacements
Old 20th September 2012, 12:53 PM   #21
tiefbassuebertr is offline tiefbassuebertr  Germany
tiefbassuebertr's Avatar
Where is mounted the X-over in a genuine TLS50 MKII ?
I want to know this to create a Bi-Amping terminal by this model.
Are there various versions of the X-over?
I have find only this:
http://avforum.no/gallery/files/1/1/8/3/1/TLS50_DF1.jpg
http://avforum.no/gallery/files/1/1/8/3/1/TLS50_DF2.jpg
found by
http://avforum.no/forum/generelt-aud...ndensator.html
more URLs:
http://www.audiokarma.org/forums/sho....php?p=6038786
http://www.marklev.com/IMF/TLS50/index.html
http://www.audiofriends.nl/archief/k...206-1977-1.jpg
Old 20th September 2012, 03:33 PM   #22
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
I can't recall for sure, been a long time since i stuck my head into an IMF TLS50, but IIRC it had the same placement as the TLS80 i broke up for parts -- right behind the midrange driver (BTW, the same picture on the MarkLev site is my scan).
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 24th August 2014, 01:28 PM   #23
Default Foam Surround replace at K040MRF (Peerless Midrange) - where?
To find singles foam surrounds is very easy:
IMF ALS 30 ALS 40 TLS 50 Super Compact Mid Repair | eBay
address is Good Hifi VOF
Myrko Schneider
Keizerfazant 29
NL-1704WL Heerhugowaard
But which repair company is able to replace those device in such case, so that I get a speaker in nearly new condition ?
The other possibility would be the use of new midrange chassis from currently production. Which models are available and suited without modification of the genuine crossover network?
Best thanks for advices.
Some URLs:
Speaker Asylum
Peerless K040MRF info from Phase Linear Andromeda III speakers
Old 9th June 2017, 10:30 AM   #24
superlian is offline superlian  Norway
Hi
I friend have a pair of TLS-50-II and will replace the woofer:
https://www.monacor.com/de-ch/monaco...assis/sph-210/
Do we need to correct the crossover?
IMF TLS 50 II driver replacementsHide this!Advertise here!
Krell ksa 100 ksa100 mkII mk II ksa50 50 GERBER gerbers pcb files project xslavic Solid State 10 1st August 2015 08:14 PM
Driver replacements hotscot Full Range 6 10th May 2011 06:17 AM
Multi driver TLs mashaffer Subwoofers 9 8th August 2006 01:21 AM
4-5" driver 50-10,000hz chuck55 Multi-Way 10 23rd June 2006 06:00 PM
