Old 7th May 2012, 03:37 PM   #11
DrDyna is offline DrDyna  United States
DrDyna's Avatar
Originally Posted by thisisvv View Post
Now i need to learn about digital XO....can some one point me ...
i hear people use PC as well for XO....
A PC solution might be tougher to implement, it's probably easier and simpler to go with a "drop in" solution like a MiniDSP or as Cal suggested, one of the Behringer units like this one:
Behringer DCX2496 Ultradrive Pro Digital Crossover 248-669
Old 7th May 2012, 03:41 PM   #12
thanks for info thanks Cal too...
so i guess for 3 way speaker on stereo i need total of 6 amps to run with this...
Old 7th May 2012, 04:16 PM   #13
Bigun is offline Bigun  Canada
Bigun's Avatar
Originally Posted by albertli View Post
Scott,
I've been running this route for quite sometime, and this supposes to be one of the most neutral sounding speakers I've heard to date. I started out with H frame then moved to just simply OB with different drivers. Below shows the route that I've been trying up to the moment. I did try the midrange with Alpair 12 which is 8", but the one with the 12" fullrange is the latest. Sound is full, rich and more neutral to my ears.
Albert
what is that 12" - looks like you enabled an Audio Nirvana ? (AlNiCo?)
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 7th May 2012, 04:48 PM   #14
Also i have a classe ssp-300 preamp ..now to work with behringer i need to buy RCA ->XLR adapter to work properly...
Old 7th May 2012, 05:20 PM   #15
DrDyna's Avatar
A single home theater type 7 channel amplifier would probably work well too.
Old 7th May 2012, 05:28 PM   #16
want to confirm type of amp will affect too.. if it is a CLASS A amp or a simple class D 7 channel amp for cheap..
still reading about behringer ...my preamp doesnt have balanced output so i might have to get RCA ->XLR adapters..
Old 7th May 2012, 05:35 PM   #17
DrDyna's Avatar
Hm, I'd probably go with a run of the mill class A/B. If you have an existing power amplifier, you could just add a 5 channel perhaps, an Adcom or Emotiva or something like that.
Yeah, you'd have to have cables, I'd probably get or make rca -> xlr cables or get adapters for the back of the Benringer.
Old 7th May 2012, 05:38 PM   #18
I guess this would be the design
Classe ssp-300 -> RCA->XLR -> Behringer -> DIY open baffle 3 ways stereo speakers...
i guess there i can configure XO and this should work right?
Old 7th May 2012, 05:41 PM   #19
puppet is offline puppet  United States
You forgot the multichannel amp between the Behringer and the speakers.
Old 7th May 2012, 05:45 PM   #20
Yes a min of 6 channel amp
Classe ssp-300 -> RCA->XLR -> Behringer ->6 channel amp ->DIY open baffle 3 ways stereo speakers
Am i right to assume this gives me versatility to have more DIY speaker later and i can use Behringer to test the speaker/ drivers...
so this solution provides me more versatility if tomorrow i want to change my drivers i just reconfigure the Behringer and according to my taste change the XO..
NO Baffle 3 way speaker thisisvv Full Range 3 7th May 2012 06:10 AM
Chill-Baffle speaker (L-baffle design) fedde Full Range 7 26th September 2010 12:38 PM
Copyright ©1999-2013 diyAudio
