I would like to cut a gasket to size (inner circle and outer circle) in leatherette or foam to cover the face of a dynaaudio tweeter. This is to reduce slight sibilance.
Does anyone know of a gasket manufacturer in uk or europe who will cur to size? I also need to stick the gasket to the tweeter face firmly but be able to remove it for resale. Any suggestion? The type of felt 'lens' they sell are no good as they have too drastic an effect. |
#2 |
I used 1/8 black neoprene. It seems to work well and it's easy to cut (with blade and template).
It's been a long time since I built my last set of speakers
www.audiosector.com “Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC |
#3 |
You should do OK with a scalpel (new blade) and a guide of some sort. If you get into trouble mail me and I'll sort out something. (I make the cutters for a living)
Rob |
#4 |
Gasket circle cutters are not expensive tools, alternate mount a blade on home-made trammel.
cyclotronguy |
#5 |
[QUOTE]Originally posted by Peter Daniel
[B]I used 1/8 black neoprene. It seems to work well and it's easy to cut (with blade and template). ------------------------------------------------------------ How do you glue it properly knowing it's going to be removable? ------------------------------------------------------------- [QUOTE]Originally posted by cyclotronguy [B]Gasket circle cutters are not expensive tools, alternate mount a blade on home-made trammel. --------------------------------------------------------------- Can you please give me the source for cutters? |
#6 |
""Can you please give me the source for cutters?""
Look in the yellow pages under die-makers, or cutting formes suppliers. If you seriously want to buy one then I'd guesstimate around £20 - £30 for a tool, and reckon on asking them to cut it if they have a small press at their premises. That's why I suggested the scalpel route..... Rob |
#7 |
x-acto or olfa make blade-holding compasses, they might do the trick.
around here one can find small (6"x6") sheets of gasket material - rubber, cork, etc. - at a good hardware store. anyplace that sells lots of plumbing or hvac supplies ought to have that stuff. for removable adhesive, the only things i can think of are double-sided tape, or rubber cement. and i dunno if rubber cement actually works on, uh, rubber. /andrew |
#8 |
[QUOTE]Originally posted by RobWells
[B]""Can you please give me the source for cutters?"" Look in the yellow pages under die-makers, or cutting formes suppliers. If you seriously want to buy one then I'd guesstimate around £20 - £30 for a tool, and reckon on asking them to cut it if they have a small press at their premises. ---------------------------------------------------------- Who sells the tools in UK please. I did a search and came up with nothing useful. |
#9 | |
[QUOTE]Originally posted by fmak
#10 |
Ok, off the top of my head....
Ashwell Dies Atlas Laser Dies Laserline Laserformes Make-a-die Seaford cutters Arden dies ""Who sells the tools in UK please. I did a search and came up with nothing useful."" http://search.yahoo.com/search?p=cut...TF-8&fr=fp-top 10 pages of results from yahoo - using 'cutting formes uk' as the search phrase - how hard did you look Rob |
| cutting dust cover off of fostex fe166 | fin1bxn | Full Range | 27 | 9th May 2007 10:47 PM |
| Looking for a Cover.... | TubeHead Johnny | Tubes / Valves | 0 | 11th January 2007 12:09 AM |
| Transformer Cover | FrankRoss | Parts | 3 | 7th December 2004 06:49 AM |
| Best way to cover a box?!?! | WhiteBoyChriss | Multi-Way | 27 | 10th November 2002 10:19 AM |
| Page generated in 0.09772 seconds (79.12% PHP - 20.88% MySQL) with 10 queries |
