High Frequency Compression Driver Evaluation
Old 10th May 2012, 09:27 AM   #31
blakkshepeaudio is offline blakkshepeaudio  Australia
blakkshepeaudio's Avatar
Wow, it's going to take a while to assimilate all this info.
Big up for all the work and the serious attempt to provide a valid and meaningful set of tests. DIY to-the-max.
Rgds,
blakkisblakk
Old 10th May 2012, 02:41 PM   #32
keto is offline keto  Mexico
Thats an amazing report! It looks like the BMS 4550 is a little bit more powerful than the BMS 4552 in the lowest part of the pass-band. For a Unity/Synergy horn, with a 4th-order effective high-pass (and 10-15dB of padding due to EQ) at 1200hz, and judging from all your measurements and listening, would there be much of a performance difference between the two drivers?
Old 10th May 2012, 04:29 PM   #33
weltersys is offline weltersys  United States
weltersys's Avatar
There would not be much difference at 1200 Hz, but the 3 dB difference below 1200 Hz is enough to make me favor the 4550 if the cones used below it were not flat to 1200 Hz.
Art
Old 12th May 2012, 05:45 PM   #34
All the graphs I've seen make the 52ND look a little "smoother" than the 50. Does it sound a little smoother?
Old 12th May 2012, 06:07 PM   #35
weltersys's Avatar
Keto,
The difference in “smoothness” is quite little as you can see in post #33, the 4552 having a slight peak around 5000 Hz, the 4550 two small dips around 6500 and 8500.
It could be argued that the 4550, with lower and upper response more equal in level, is “smoother “ than the 4552.
The recordings were posted for you to listen to and make your own decisions, please share which sounds “smoother” to you.
Art
Old 15th May 2012, 10:47 PM   #36
Hentai is offline Hentai  Japan
Art,
Thanks for this impressive effort. The uploads are sure of great value for diy community.
The B&C performed pretty well.
I have a question though. I'm trying to figure a DIY compression driver and what I've noticed it behaves quite differently when modeling is done with different types of horns.
So my question/concern is that the test are only conclusive on that type of horn. Could the results be different with another horn?
If this matter has already been addressed please direct me to it.
I have seen many agitated spirits here so don't take my question the wrong way, its just a concern i stated in another topic i opened on compression drivers.
Old 16th May 2012, 02:17 AM   #37
weltersys's Avatar
Different horns using the same driver will result in different frequency response, pattern control, sensitivity, diffraction effects etc.
The relative differences in the drivers in my test can be interpolated to how they would respond on other horns.
Good luck with your DIY compression driver project.
Old 19th November 2013, 01:41 PM   #38
keyser is offline keyser  Netherlands
keyser's Avatar
Woow... I'm impressed! I'll do some listening tests when I find the time. Many thanks for sharing!
Dutch & Dutch
Old 6th December 2013, 11:52 PM   #39
ra7 is offline ra7  United States
Art, I had looked at this several times, but never posted. I read Pano's summary above, and the first post could really use this high level summary. Could you add an abstract summarizing the test?
This is tremendous work. I haven't yet listened to the files, but I will soon.
Thanks!
Old 7th December 2013, 05:19 PM   #40
weltersys's Avatar
Thanks!
Good point, summary added to the top of the (rambling) first post.
Had to edit the post just to fit it in, was already at the 30,000 word limit .
High Frequency Compression Driver EvaluationHide this!Advertise here!
ULTRA-high frequency driver impedance vs. Class D amps? head_unit Multi-Way 8 22nd January 2012 07:37 AM
Wanted - High Power, High Voltage, Audio Frequency Transformer Manual. kimbal Tubes / Valves 4 11th May 2009 09:05 PM
Compression driver frequency response? jayam000 Multi-Way 2 10th May 2009 05:26 PM
FS: Silver Iris Coaxial 15" driver pair (sans XO and compression driver) theAnonymous1 Swap Meet 0 24th April 2007 01:09 AM
This amplifier is distorting high frequency, some audio compression too. Know why? destroyer X Solid State 97 8th November 2004 03:46 PM
Copyright ©1999-2017 diyAudio
