Problem in response
Problem in response
Old 13th May 2012, 12:15 PM   #41
pk2carlos is offline pk2carlos  Slovenia
Thanks for idea, will try to do something about it when I have time :-)
Old 13th May 2012, 06:48 PM   #42
mdocod is offline mdocod  United States
Send a message via AIM to mdocod
Why? It 's not strong enough to even show up in combined response. I'd suggest pretending like you never noticed that hump in port response and enjoy the darn speakers.
Old 14th May 2012, 07:34 AM   #43
Yes you are right.
From the start I made some reinforcment that I didn't instaled so will try them now and see if they can breake some of this standing waves. Those reinforcments will fit right in so it is very easy for me to test it.
Also I have to make new front panel to fit smaller port, I didn't use the one that will be in final version, in fact the port that I use now is 27 cm long and it is also on the outside of the box :-)
Old 3rd January 2013, 02:59 PM   #44
Joel Wesseling is offline Joel Wesseling  Canada
Originally Posted by pk2carlos View Post
Yes you are right.
Did you get this sorted out.. The dip etc.. I'm thinking about trying a pair of these..
How do they sound? Vocals,bass, treble on it own, Soundstage, treble woof integration, how loud before woofer over extends etc..
Kind Regards, Joel
Old 4th January 2013, 08:27 AM   #45
Hi Jole,
Dip in response was result of room that I made measurement and if I remember correctly the peak of bass reflex port has gone with some more damping, would have to look mesurments again, but anyway it isn't a problem.
Sound is very good, so I do recommend you to try them. There is no problem as far as I can hear with treble/woofer integration. I listen to them in a small room 4 by 4 meters and they are simply loud enough, also in bass range.
For me it is a very simple and very good project, so I do recommend it to anyone to give them a try. I like it more than B 80, but B 200 is better and also different price.
Old 5th January 2013, 02:56 AM   #46
Thanks Carlos
I'm still searching for possibilities but looks like a good choice and simple way to get a tweeter into a design...
More time needed before I go forward..
Old 20th September 2014, 06:05 PM   #47
Here is the final product, colour selectiond by my one and only boss to met WAF standards
Still on to do list is to play with damping, but it is hard since it is another room and system, so I don't know what to expect.
All in all it is a nice speaker for audio/video duty, kind of allrounder for a tipical EU sized room (4x4 meters) and very simple to build.
Mesurment is made at 0, 15, 30 and 45, spacing on the vertical scale is 5 dB.
Old 20th September 2014, 06:35 PM   #48
system7 is offline system7  United Kingdom
system7's Avatar
I'm late seeing this thread, and people have alluded to a room effect already, but the dip at 150Hz looks very like the Allison Effect. It is a result of the out-of-phase bass image from the nearest boundary cancelling the main drivers output.
Very nice looking speaker. Nice work. Looks like the bass loading (Qts 0.5, Vas 5.1L) and cabinet is all there is to do, since the crossover is built in.
HX 10 - 4 Ohm
I'd guess you could run the bass with the suggested loadings of the similar W 100 S - 4 Ohm in Visaton Boxsim
Looks to me like your original port was way too big, eh? Damping a reflex is usually done with rubbery stuff stuck to the sides, leaving the enclosure largely empty IIRC.
Best Regards from Steve in Portsmouth, UK.
Old 20th September 2014, 07:42 PM   #49
Yes, that was it.
HX 10 - 4 Ohm
Boxsim is a greate software especialy for Visaton drivers. I us it to calculate volumen for all drivers that I use.
Can we say that the port was too short
I don't know where it went wrong with calculations, but when I made calculation it was ok on a paper. Well lesson learned and now I'm more cerfule doing it :-)
Problem in responseHide this!Advertise here!
in-room frequency response & transient response MCPete Multi-Way 1 8th October 2011 07:31 AM
Problem with calculation of phase response (time zero) pawelpl Software Tools 2 4th July 2011 11:28 AM
Speaker Workshop Pulse Response measurement problem mightydub Multi-Way 0 10th February 2007 07:53 AM
Speaker Response Problem sma Multi-Way 13 16th July 2004 11:56 PM
Doubts on Phase Response and Frequency Response dumrum Multi-Way 11 5th April 2004 11:39 AM
Copyright ©1999-2017 diyAudio
