Old 5th May 2012, 05:16 AM   #11
system7 is offline system7  United Kingdom
system7's Avatar
Originally Posted by sreten View Post
No its not. There is no cosmetic trim. Baffle needs modding for other drivers.
rgds, sreten.
yes it is!
rgds, steven.
Just a question of finding something that fits...
Economy SPW165
Frame size: 165mm
Overall depth (front of frame to rear of magnet): 75mm
Flange thickness: 3mm
Fixing holes: 4 x 5mm diameter on 175mm PCD
Cutout diameter: 150mm
maybe...
Good Night, and Good Luck. Best regards from Steve in Portsmouth, UK.
Old 5th May 2012, 09:15 PM   #12
Looks like you are right, and my apologies for saying the contrary.
rgds, sreten.
There is nothing so practical as a really good theory - Ludwig Boltzmann
When your only tool is a hammer, every problem looks like a nail - Abraham Maslow
Old 7th May 2012, 04:08 PM   #13
Wow, thanks for all the replies!
sreten, no, the sounds quality seems uneffected. I don't hear any buzzing or cracking.. it might be cosmetic, but I'm hesitant to turn up the volume incase I do damage these speakers - they're my only pair of speakers in the house!
The guy in New Zealand who repaired these speakers in a previous link just replaced the cones with black kevlar, not the entire unit.
So in terms of steps I need to take, do I just order one of those 8ohm drivers and take my chances? Also, it worthwhile to stuff some polyfill (as per the picture above)? The speaker comes unstuffed from the factory.
Thanks!
Old 7th May 2012, 07:43 PM   #14
If they are not cracks, just cosmetic discolouration, I'd spray the cones
with some black paint and leave as is. Better drivers would be good, but
very hard to pick regarding matching the original x/o.
rgds, sreten.
Old 7th May 2012, 07:50 PM   #15
lduarte1973's Avatar
maybe it´s time you diy some new ones ?
Hey ! just because i´m going bald doesnt mean i cant like hair metal
Old 7th May 2012, 07:53 PM   #16
merlin2069er's Avatar
Send a message via MSN to merlin2069er
Good luck. I tried looking for a tweeter replacement for a pair of Wharfedale Diamond speakers (no luck).
Old 8th May 2012, 02:44 AM   #17
system7's Avatar
Thanks!
People won't tell you this, but building speakers is not hard!
Most 6.5" drivers will work in a 15L box. You can play with stuffing and blocking the reflex ports to taste. You can add some cheap 10W wirewound resistors to the tweeter to match the levels. Nothing very critical here. This is not a studio monitor. Like I said, almost anything that fits will likely do, but we'd happily check a locally available contender for you on Qts and Vas an all that. Don't see why you couldn't file off the bumps and fit with bolts either.
Old 8th May 2012, 11:15 AM   #18
DavidL is offline DavidL  United States
DavidL's Avatar
I respectively disagree. Not just "any" driver will give him good results. Yes, the QTS, FS and VAS need to fit the desired box size along with an impedance range very close to the original driver, similar frequency response AND driver sensitivity, otherwise it's a crap shoot. Designing a well done speaker IS hard work and not just plunking any driver that fits into the box.I'm guessing he doesn't want to have to wade through 5 or 10 different drivers to get one that kind of works.
Old 8th May 2012, 03:17 PM   #19
Just doing some quick math, 130 millimeters = 5.12 inches. So would I be shopping for a 5 inch driver? or 5 1/4 inch driver.
lduarte1973, DavidL - I agree that a good sounding speaker requires more than dropping in a driver, I'll be trying my hands as building a speaker for the first time (that's for another thread). For this Mission, I'd just like it repaired and not sounding worst than the original design.
Thanks everyone for the replies!
Old 8th May 2012, 06:16 PM   #20
system7's Avatar
Mate, you need better than maths at this stage, you need the other engineering skills of SURVEYING and MEASUREMENT if you're gonna progress...
The other issues come later. First find some stuff that might fit. This is what we call being on the "Critical Path" to a solution in civil engineering terms. You do the groundwork first in simple terms.
Has anyone used these mission woofers before? mondogenerator Multi-Way 30 3rd March 2013 09:48 PM
Mission Cambridge amplifier - Mission Power Amp Module 1 Aleko Solid State 1 18th May 2011 01:14 PM
Peerless 12" Subwoofer and Mission 4" Woofers viki_v2 Swap Meet 0 24th January 2011 12:39 PM
WTB: Vifa P22WP-01 Woofers (surplus 8" Mackie woofers) gtforme00 Swap Meet 9 3rd June 2008 09:57 PM
Replacing woofers/foam in Bang and Olufsen speakers camshaft Multi-Way 5 10th April 2007 05:57 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
