WLM Stella clone
WLM Stella clone
Old 9th May 2012, 12:22 AM   #11
samadhi is offline samadhi
How does the tweeter sound, samadhi? Like a soft dome? I couldn't help noticing that keeping all the drivers paper seems to produce a nice synergy on some of the resonances. Interesting.
Its sounds better than a soft dome to me in the lower treble frequencies, and the sound is cohesive, easy to blend with the woofer without much tweaking of the crossover. Though the upper end is less detailed and fairly directional. A tiny neo tweeter on top might make for an unusal but nice sounding little 3-way.
Old 9th May 2012, 01:13 AM   #12
system7 is offline system7  United Kingdom
system7's Avatar
Well, I've got some good news on crossovers, samadhi. The FRS5X8 is slightly superior on directivity due to it's little hard dome at the centre, but actually doesn't sim as well on the simple series crossover here, though it works without component changes. And series is what WLM must be using on the Stella since nothing else works as well!
Here it is for mounting against a wall. No standmounters from me! But I suspect it'll be VERY GOOD!
FWIW, I found the bigger La Scala worked very well with an AR-SXO crossover. A mere 3 components including the resistor across the bass. But then the W200S is a different animal from the trickier W130S with its horrible 1400Hz peak, which kinda gets cancelled out her in phaseyness.
Best Regards from Steve in Portsmouth, UK.
Old 9th May 2012, 09:32 AM   #13
burgunder is offline burgunder  Denmark
This is great!
Did you BTW ever finish the "Scala" version you were contemplating, Steve?
/Claus
Old 9th May 2012, 12:30 PM   #14
AllenB is offline AllenB  Australia
If, as I suspect, you mean that it is wide up to a higher frequency then I might throw my 2c in to the other ring. A narrowing dispersion will help with clarity, with the tradeoff being a narrow sweet spot. To me this is the benefit of using a cone tweeter.
Old 27th September 2012, 08:51 PM   #15
Ostry11 is offline Ostry11
Hi guys,
I would like to make this loudspeaker, but with bass reflex on the front panel, or down (like stand version) Can someone help me with box project?
Old 18th November 2012, 02:14 PM   #16
tiefbassuebertr is offline tiefbassuebertr  Germany
tiefbassuebertr's Avatar
Originally Posted by samadhi View Post
Here is a little project I have been working on over the past few weeks. Its a "clone" of the WLM Stella bookshelf speaker.
It uses the Visaton drivers W130S 5" mid-woofer and TW70 paper cone tweeter.
The tweeter has a fast rolloff below 1.4khz and 4th order acoustic slope can be achieved with just a capacitor. The W130S sounds very smooth and has good bass response for such a small woofer.
Some measurements to come shortly.
Good approach for a good sounded loudspeaker and cheap to build loudspeaker at the same time.
Here a small listening report in German from a similar version:
http://www.lautsprechershop.de/index...hifi/ct246.htm
I don't understand this term:
Mean you the genuine device or the clone ?
In this case this threads could be of interest:
http://www.diyaudio.com/forums/multi...id-wanted.html
http://www.diyaudio.com/forums/multi...r-tweeter.html
Old 18th November 2012, 02:37 PM   #17
system7's Avatar
Having modelled the WLM clones in Boxsim, I can add that the Visaton 4" W100S and 6" W170S bass drivers are far easier than the W130S and W200S.
They don't have the peaks in frequency response that the WLM choices give when you filter them. A simple 2nd order bass, third order treble and padding for level on the TW70 just works nicely.
That's where I would go on a smallish speaker in this style.
WLM Stella cloneHide this!Advertise here!
Visaton Stella - any thoughts? DIYNick Multi-Way 62 26th May 2012 06:42 PM
Clone reteP2k Tubes / Valves 3 31st December 2011 06:01 PM
Rhino Stella Utopia, Nautilus and Isis designs ale3hs Parts 0 11th May 2010 05:33 AM
what are WLM DIVA speakers made of? qubix Multi-Way 5 30th October 2006 10:05 AM
Question regarding ProAc 2.5 Clone and Tempo 2 Clone zoooh Multi-Way 5 11th March 2003 09:19 PM
